iFi audio iDefender3.0 (Official) - Ground Loop Eliminator
post-14744625
Post #46 of 63
rafabro
Will iFi Audio iDefender 3.0 work without power supply? My USB converter doesn't require power and is switched off on USB card. Will iFi Audio iDefender 3.0 transmit signal anyway?
post-14747716
Post #47 of 63
iFi audio
Sponsor: iFi Audio
Website
ifi-audio.com
If your DAC is self-powered, then yes, iDefender3.0 doesn't need separate power supply. If your DAC runs on 5V, then you need one.
iFi audio Stay updated on iFi audio at their sponsor page on Head-Fi.
https://www.facebook.com/iFiAudio/ https://twitter.com/ifiaudio https://www.instagram.com/ifiaudio/ https://ifi-audio.com/ info@ifi-audio.com
Reactions: rafabro
post-14772550
Post #48 of 63
iFi audio
Sponsor: iFi Audio
Website
ifi-audio.com
post-14879344
Post #49 of 63
stuck limo
Member of the Trade: LH Labs
What do you mean by "self powered"? Do you mean off a battery? My DAC runs off USB power, so I was required to purchase a separate power source to plug in.
post-14879403
Post #50 of 63
rafabro
Reactions: stuck limo
post-14879413
Post #51 of 63
stuck limo
This mean own power supply without need of power from USB.
Yep, got it. My equipment should be coming on Monday so it'll be interesting to see how it operates.
post-14880343
Post #52 of 63
iFi audio
Sponsor: iFi Audio
Website
ifi-audio.com
post-14975481
Post #53 of 63
Yviena
Norway
Norway
@iFi audio according to RME cutting out the 5v/gnd makes the usb cable not pass EMI tests anymore due to shielding, i'm wondering how does the idefender make sure that the shield is still effective in the usb cable.
You not pass EMI tests anymore. It's not only about internal GND, but also shield. Commercial units therefore need to connect everything as suggested by the standard.
Connecting only the data lines has the potential to fry the USB chip port with unexpected static or spike electricity, either when switching units on/off or by disconnecting/connecting.
post-14978491
Post #54 of 63
iFi audio
Sponsor: iFi Audio
Website
ifi-audio.com
We'll ask our tech team about this.
post-15166014
Post #55 of 63
slex
Just checking, does anyone uses idefender on thier android phones?
Like-- Smartphones --OTG--idefender 3(injected with 5V )-dac that need external power?
Hoping to supply enough power to dac without draining power from phones.
post-15171147
Post #56 of 63
iFi audio
Sponsor: iFi Audio
Website
ifi-audio.com
It should work, though iDefender should go in before your OTG cable.
post-15171168
Post #57 of 63
slex
Hmmm, need USB C to USB A Female adapter to fit the idefender first to the phones.
post-15236923
Post #58 of 63
Yviena
Norway
Norway
@iFi audio just wondering but how do i know if the idefender is letting 5v through, or not from the PC, does the led light turn off, or something...
post-15238502
Post #59 of 63
iFi audio
Sponsor: iFi Audio
Website
ifi-audio.com
Reactions: Dobrescu George
post-15607358
Post #60 of 63
Dobrescu George
Reviewer: AudiophileHeaven
Bucharest, Romania
Bucharest, Romania
Age
25
Website
audiophile-heaven.com
It works pretty well on my end, although I have to admit, my PC was quite noisy to begin with, the PSU is kind of old, and the motherboard was noisy with everything. Happily, it works and I can hear the differences with a ton of equipment.
iFi-iDefender-PLUS-idefender+-3.0-USB-Grounding-Loop-Insulator-Power-Injector-Audiophile-Heave...jpg
