Middy
http://ifi-audio.com/portfolio-view/accessory-idefender3-0/
I am not sure the 5V will have an effect but a ground lift may do. Thier ISO lift may do the same as a manual lift on the GND..You could try a straw or something to block the 5V and see if the opposite works as your DAC is self powered. A manual ground lift is not too hard on a diy basis you could just cut the ground and touch bare wire until lock.....
Or spend £40 and try.
I am not expert just trying things...
