- Mar 7, 2007
Yeah, thanks for the run-down.
My impression for iFi GO blu.
Build quality is solid and is certainly the best looking Bluetooth dongle I ever have. It's also very small and light, you can see the comparison in size with other Bluetooth dongle I had (BTR5, Qudelix, UP5).
Sound-wise, the first thing that comes to mind is that it is pretty warm and full bodied. The easiest way to explain is that it feels like it has a tube-like sound. The vocal is sweet and smooth with the GO blu. Enjoyable.
However, compared to the UP5, it wasn't as clean sounding. A slight hiss is audible in a silent passage if your music have it, which isn't much of an issue once the music start blending, but noticable nonetheless.
Bass in the UP5 is faster and snappier, while GO blu is a little bit boomy, but still pretty much competent. I never feel like it is slow, but just not as snappy as UP5 is. The Xbass feature is a nice addition though, adding a subtle boost in bass response, while not affecting other frequency.
Mid is warmer and thicker than the UP5. Doesn't mean the UP5 is cold, I think it still has warmth in it, but certainly not as warm as GO blu. Personally, I really like the mid of GO blu, however, if we are talking about technicality, I had to give the upper hand to UP5.
Going to the treble, the UP5 is certainly more prominent and sharp. The GO blu is a bit more relaxed. If your headphones have sibilance or you want to reduce it a bit, the GO blu can do that. The UP5 will just render everything as it is.
Staging-wise, I feel the GO blu is a bit more intimate, however the Xspace feature could expand it a bit. UP5 soundstage is probably more in line with GO blu + Xspace feature turned on.
Feature-wise, the GO blu is more barebone. Unlike other manufacturer, iFi doesn't include a companion app and there is no display. This means some features from the competitor isn't there, i.e the ability to select DAC filter, selecting just specific codec, EQ or even just turning the charging on and off when using as wired DAC.
Overall, I like the GO blu. It certainly has it appeals, the build quality is solid, it is small and very light. The sound has a tube-like quality which can works really well in some pairing. However, I would still say the technicality of the UP5 is better and also pack more features.
Still, audio is subjective and I found the GO blu to be a better pairing to my FW1500, which for the longest time, I wanted to fix the harshness in the upper mid region and the GO blu delivers. So I'm happy.
It really is tiny isn't it!
How does it compare (sound wise) directly to the Q5?
