iBasso DX50 MODS
post-11909781
Post #256 of 374
shagrathborgir
First try out some babs recommendations! Don`t start to invent bicycle again :rolleyes:
I`m probably going to try out ADA4897-1ARZ sometime in future.
I allready tryed that,and had problems after few days...rembember the right channel popping!I sent the unit to ibasso,and they replaced the ada amps with the stock ones,they said that the right channel one was dead or something.they charge 10 usd for everything,so postal taxes and time worth more than that.i was asking about opa1611 as dx90 have them,and fiio x5 also!!!maybe babs can tell us what we get and what we have to loose!
post-11910002
Post #257 of 374
CoiL
Member of the Trade: Wood Audio Accessories & Modifications
Estonia
Estonia
LOL! Sorry, but You and modifications (done by yourself) don`t go hand-by-hand
Are You saying that babs recommended HO opamps (ADA-4897-1ARZ - that work well for him!) cause problems after few days? I think no!
Sorry to say this, but I think You don`t have enough skills to do these modifications and no idea what exactly You are doing.
Now, stop "insulting" babs for Your mistakes!
No-one asked You to do these modifications and if modifications aren`t handled out with care, then things can go wrong.
Funny that it`s only You in this thread having problems all the time
post-11910082
Post #258 of 374
shagrathborgir
did I blame babs???NO!I did almost everything babs did...don't have a clue why that ada amp died,that's what ibasso team told me that causes the problem!maybe it was bad luck with one amp unit!they just pit stock ones back,and everything was fine!
did I said that I did the mods by myself???NO,once again!!!yes,I don't have enough skills,this is why I always solder and repair what I know I can to right...for example,I have repaired and replaced a lot on a pcb from a jbl e250 sub...modded creative sound card...etc
I can always replace the sctock amps with ada ones,my question was if the opa 1611 is a better choice,since dx90 and fiio x5 have them inside!!!
you're giving me the same answer every time,even if I write you the same things over and over again,that I did not modd is by myself,and I did not blame babs or you,or the guy who solder them...even babs said that ADA-4897-2ARZ was soldered good,and that's a tough one,also his words!!!
I had a problem,and I'm not the only one...there are people who had problems even with stock unit,so I'm not the only one.still,my problem is solved since few moths,I'm just looking for another solution.do I have to change my nickname so you can answer me like you do to all other people???
post-11910294
Post #259 of 374
CoiL
Estonia
Estonia
Calm down.
It`s just the way You write and say things.
  did I blame babs???
Not directly... but...
...maybe babs can tell us what we get and what we have to loose!
Sound pretty accusing to me
 But sorry if I misunderstood. Maybe choose/write Your words more carefully?
For example would have been nice to start with saying that.
We are talking about modified unit and modifications NOT stock DX50 - different things, different threads.
post-11912355
Post #260 of 374
shagrathborgir
ok..maybe this time I make myself clear!
I DID NOT MODD MY DX50 BY MYSELF,A FRIEND DID THAT.HE HAS A REPAIR PHONE SHOP
I DO NOT BLAME SOMEONE FOR WHAT WENT WRONG WITH MY UNIT
I HAVE REPAIRED MY UNIT AT IBASSO,THE FAULT WAS ONE OF THE ADA HO AMPS
I WANT TO REPLACE THE STOCK HO AMPS WITH SOMETHING ELSE,MAYBE ADA AGAIN,BUT I'M ALSO INTERESTED IN OPA1611 FOUND ON DX90 AND FIIO X5
THANK YOU BABS FOR THIS THREAD!!!
Again,will opa 1611 be a better choice than what babs used for HO??babs,have you tried opa1611 before ada amps???can you explain what we could gain,and loose with opa1611??since you know best what you're doing I'm sure you can explain this to us!!thank you
post-11916715
Post #261 of 374
babs
I didn't test the OPA1611,( too much work for changing these OP )
But they seem OK for the application
I choose the ADA4897 mainly for their output current drive power; 80mA (vs less than 40mA for the OPA)
I have low impedance IEM, so the current drive of the amps is important for me
The ADA is designed to work with a 100ohms load, for the OPA, there is nothing specified under 2Kohms
And spec-wise, the ADA is much better than the OPA, except for the input bias current
Anyway, the only way to really test the sound quality of the OPA is to try it...
post-11916753
Post #262 of 374
shagrathborgir
yes,of course....the best way is to test them!
really don't know what to choose,as iem's will always be no more than 32ohms for me and the ones I want now,have 150mw input power....jvc fxz2000,and I don't understand how will they work with ibasso dx50.my actual headphones have 250mw input power
the stock amps data sheet will be helpful to check
thank you babs...if you could explain me this thing with iems and input power,how does it work....I'll thank you again! :)
post-11923851
Post #263 of 374
B3H3M0T
post-11947600
Post #264 of 374
mogi
Hi guys i need some help in identifying the part number for the lock button as i have accidentally broken it during the upgrade of my dx50 opamp... its fragile and snap off during the removal of the pcb... Your help is really appreciated as of now i have a broken lock switch...
Edit: Is this the correct replacement slide switch?
http://www.digikey.sg/product-detail/en/CUS-12TB/563-1102-1-ND/1124231
post-11947833
Post #265 of 374
shagrathborgir
you could always send ibasso team a message with you're problem!I had more serious problems than yours,and they are really helpful!I'm sure they will send you the original part,and charge you not more than 5$ including the postal taxes,as they charge 10$ for any kind of repair (I don't know about the screen cost).the harder part is time,it will take more than 2 weeks,but that's how things are with China!you cand also ask them if what you found is the same slide,and tell them that is faster that way!good luck
post-11948092
Post #266 of 374
mogi
Thk for the info shagrathborgir! I have just drop them an email regarding the lock button (slide switch) and to check with them if it is the same version as the one that I have found if it is made by Copal electronics. :)
post-11950141
Post #267 of 374
babs
Power button: Panasonic : #EVQ-P7C01P   Lock button: C&K : #SK-12C0405-SG 1.5 RT   I found them on Digi-Key
http://www.digikey.ca/product-detail/en/0/CKN10374CT-ND
http://www.digikey.ca/product-detail/en/0/P16765CT-ND
Reactions: CoiL
post-11950200
Post #268 of 374
mogi
Hi Babs, thanks for the parts recommendation i got this from RS Components which i installed and is working fine finally my lock switch is as good as new (It was getting loose due to the constant locking usage before i damage it during the disassemble).  :D
http://sg.rs-online.com/web/p/slide-switches/6023633/?searchTerm=602-3633&relevancy-data=636F3D3126696E3D4931384E525353746F636B4E756D6265724D504E266C753D656E266D6D3D6D61746368616C6C26706D3D5E5C647B337D5B5C732D2F255C2E2C5D5C647B332C347D2426706F3D313426736E3D592673743D52535F53544F434B5F4E554D4245522677633D4E4F4E45267573743D3630322D3336333326
post-11950204
Post #269 of 374
mogi
After searching through the thread i think the ground pin may not be touching the battery cover fully..
post-11953162
Post #270 of 374
Gourmand
Hi All. Here I discovered MAL203854331E3 Vishay 330uF 10V caps were best for replacement. But unfortunately they were... discontinued. :frowning2: I can't find them in any web shop close to me. Anybody had tested more caps? What about Panasonic AM 330uF 10V ECA1AAM331X, NHG series ECA1AHG331? United Chemi-Con EKMG100ELL331MF11D? Nichicon UVZ1A331MED1TD? Jamicon TKR331M1CF11? All of them have size 6.3x11 mm. But what about sound quality?... And Rubicon 10ZLH330MEFC6.3X11? They can fit too. But sound??
I wanna replace to 330 uF only for lower frequency filtering.
Looks like replacement of Vishay MAL203854331E3 is MAL214254331E3. But I even can't find them in store.
Did not find 330 uF 10V Vishay, ordering 220uF... :-\  MAL203854221E3 is this right?
