DX220 A new view to your music. *** LATEST FW: 1.19 Local *** Link for User Guide 1st Page.
Apr 24, 2019 at 2:36 PM Post #1,101 of 13,478
I predict a lot of "nearly new" Amp1 MKII's for sale on here after the worldwide release of the DX220. :)
If it's like the upgraded Amp1 from the DX200Ti then it'll be a keeper. I sold my Amp8 and only use the Ti Amp1 now
Apr 24, 2019 at 3:35 PM Post #1,102 of 13,478
if not expensive I would buy 2... for experiments:ksc75smile:
You can totally make your regular Amp1 into Amp1 MKII, and even with some variations.
Agreed, the Amp1Ti is great! The Amp8 though is still better if you need to drive it with full-size. On top of that, the Amp8 can easily surpass the stock form with modifications, where as the Amp1Ti is already what it is....Modified
Apr 24, 2019 at 3:42 PM Post #1,104 of 13,478
Yeah, the original AMP1 was kind of thin and bright. But this AMP1MkII is... robust. Very impressive.
Apr 24, 2019 at 4:06 PM Post #1,105 of 13,478
Apr 24, 2019 at 4:11 PM Post #1,107 of 13,478
Apr 24, 2019 at 4:36 PM Post #1,109 of 13,478
Is amp8 changing with the dx220 or will it be the same? Why is there an average playtime for the amp module itself?
Just like how you are driving your car. Change the way you drive from casual commute into racing style, floor the gas pedal every time, and slam the brakes, then your care tires, brakes, gas would be consumed much faster.
Amp module is designed differently, different power consumption, battery playback time is affected
Apr 24, 2019 at 4:40 PM Post #1,110 of 13,478
Wow, this would be the lowest duration of any dap I've encountered. Is it worth it? I presume the amp isn't changing. Which amps are being updated with the DX220 if any? It's not like 4.4mm balanced is unavailable on other daps either. Amp8 must be quite special or iBasso are just generally lagging behind others, especially with only one of their amps having that output.
