MKnopfler
- Mar 16, 2017
For my Lexus GX470 I'm currently using the DX200 via mini toslink into a Helix DSP Pro which I control with the Helix Director Module. The Helix feed 2 JL HD600 and a HD1200 amps. I have a 3 way set up in the front using Audiofrog GB60, GB40 and GB10 plus GS62 fills in the rear doors. Those 8 speakers are run by the twin HD600 amps in an active set. The HD1200 powers a GB12D4 sub in a sealed enclosure. It has a great, clean sound. The difference between the DX80 and the stock Head Unit (which is still hooked up and usable) was immediately noticeable. After a good long burn in, 400+ hours the difference was night and day.
Upon first trying the DX200, I hated the lack of midbass as compared to the DX80 in the same set up. After 400+ hours of burning in the sound on the DX200 has really opened up and tightened up while the highs are bright but not brash. Amazing difference that the proper burn in makes. The DX200 will definitely be staying as my "go to" audio player. The DX80 is being retired or used at work now I'd guess.
So I'm most excited about your Upgraded Purist rom. The sound in my car is already amazing, with this upgrade I'll prolly be burning even more gas driving around with a huge grin blasting Led Zeppelin, Pink Floyd, Dire Straits, AC/DC, Sam Cooke, Stevie Wonder, Steely Dan, Herbie Hancock, etc
