mbwilson111
- Oct 13, 2016
My experience having had the dx120 for a week or so is that burn-in does make a considerable difference. i found it too bright at first with single-ended but it settled down after many hours as i was too impatient to use the burn-in cable, i then switched to balanced and found it even more bright and difficult to listen to, Paul at ibasso suggested using the burn-in cable and i did so using a burn-in track on loop for about 40 hours, this made a real difference,.
So best to burn in for the recommended 100 hours although it maybe possible to reduce this by using a specific burn-in track (the one i use suggest it is 4 times as effective as normal music) i use professor johnsons from a cd i bought to check system setting years ago.
Hope this helps
d
What number should I set the volume to if I use the burn in tool balanced with regular Flac files from my sd card?
