but definitely will support the Mojo through lineout? don't wanna waste money on a cable!I asked ibasso sometime ago and the dx120 does not have the ability to output usb to mojo.
d
iBasso DX120 pure DAP player. Balanced, single ended, line out and 2 micro SD slots. FW 2.9.21 now out!
- Thread starter Paul - iBasso
i connect them through line cable to my car & my yamaha desktop preamp... idk about any mojo, but if the device have a line in port then should be right. in my country line cable start from under $1 but the quality is came with the price, but heck it makes the job done.but definitely will support the Mojo through lineout? don't wanna waste money on a cable!
Any recommendations for a decent quality lineout cable? Fiio and iBasso's own cables are impossible to find these days!i connect them through line cable to my car & my yamaha desktop preamp... idk about any mojo, but if the device have a line in port then should be right. in my country line cable start from under $1 but the quality is came with the price, but heck it makes the job done.
https://www.ugreen.com/products/right-angle-3-5mm-jack-to-jack-cableAny recommendations for a decent quality lineout cable? Fiio and iBasso's own cables are impossible to find these days!
ugreen never disappoint me so far...
Mind if I send you a PM about this? Looked at their site and the sheer number of options is kinda terrifying!!i had this problem and found the only one that worked (for me) was a standard 3.5mm interconnect for a headphone amp (the one i have is from russ andrews - kimber cable - very short) and i did some research which basically stated that there would be no differnece in sound from a coax cable (given the short length)
hope this helps
d
sureMind if I send you a PM about this? Looked at their site and the sheer number of options is kinda terrifying!!
vas-tomsk
This is not quite true. The DX120 can send a digital signal via USB, but not to all devices. For example, DAC-amplifier FX-AUDIO- D802C accepts any reproducible format, but DAC-amplifier SMSL A6 accepts only DSD. (Firmware 2.9.121-L0)dx120 can't use usb c as an output signal
nice to know, thanks for your info mate.This is not quite true. The DX120 can send a digital signal via USB, but not to all devices. For example, DAC-amplifier FX-AUDIO-D208C accepts any reproducible format, but DAC-amplifier SMSL A6 accepts only DSD. (Firmware 2.9.121-L0)
Jmop
- Sep 17, 2014
Assuming so since the 120 has a dedicated line-out, I just want to confirm that the volume will be fully controlled by the connected amp.
Jmop
- Sep 17, 2014
What amps are you guys using? I'd like to color the sound to make it less dry, unless fidelizer is that much of a night and day difference. Thinking Ray Samuels or Leckerton..
with iems i don't need amps, with hd600 i am using my yamaha desktop preamplifierWhat amps are you guys using? I'd like to color the sound to make it less dry, unless fidelizer is that much of a night and day difference. Thinking Ray Samuels or Leckerton..
Jmop
- Sep 17, 2014
Thanks, but I'm interested in portable amps to color the sound. Indeed it is good power-wise for IEMs.with iems i don't need amps, with hd600 i am using my yamaha desktop preamplifier
Jmop
- Sep 17, 2014
Bump again for what portable amps are being used with the 120.
Once my custom IC cable arrives I'll be using it with a Chord Mojo!Bump again for what portable amps are being used with the 120.
Jmop
- Sep 17, 2014
Word! Although from what I've read about the Mojo I think it might be kind of dark together since the 120 emphasizes lower treble over upper.Once my custom IC cable arrives I'll be using it with a Chord Mojo!
