Jmop
- Sep 17, 2014
My mistake, L1 is stated to be the same but with different font.No, there is only one model number - this is the DX120. L0 is a version of the custom firmware from Lurker.
Farewell.. Do you think fidelizer is a must for it? I'm on L0 now. If it makes the sound more liquid in texture and not just adding bass quantity I'll have to try it.finally since 2019 i have to say goodbye to my beloved dx120 for sold.
if u like a reather warm sounding then yes, for me the stock fw kindda dry. give it a shot, it's free anyway with the purist rom.Farewell.. Do you think fidelizer is a must for it? I'm on L0 now. If it makes the sound more liquid in texture and not just adding bass quantity I'll have to try it.
Thanks, is this the version you are referring to or the older one? https://www.fidelizer-audio.com/iba...on-2-9-121-released-with-perfectdynamics-3-0/if u like a reather warm sounding then yes, for me the stock fw kindda dry. give it a shot, it's free anyway with the purist rom.
yes that's it, just follow the instructions step by step.Thanks, is this the version you are referring to or the older one? https://www.fidelizer-audio.com/iba...on-2-9-121-released-with-perfectdynamics-3-0/
Ah, didn't see the instructions for Mac at the bottom of the page. Seems like a hassle, I'm gonna sit on it for now.yes that's it, just follow the instructions step by step.
enjoy the redefine in musicSaving this to open tomorrow but it's already here!!
anyone can CMIIW, dx120 can't use usb c as an output signal, u can use L.O port or AUX port at the top of it.
while im not familiar with the mojos and other portable amps. yes u need that. no probAh yes I remember having to use that with one of the older Fiio players I had, so I'll need a lineout cable then right? iBasso do their own IIRC? Thanks for the help!
