iBasso DX120 pure DAP player. Balanced, single ended, line out and 2 micro SD slots. FW 2.9.21 now out!
Sep 21, 2019 at 3:45 PM Post #1,788 of 2,153
I have a problem with my DX120. When i want to use the Line out port, i can adjust the Volume just like at headphone out.
The Lineout Port is the same like the headphone port. Anyone a idea whats the problem ?
That is normal. You can adjust it like a preamp or to max or less, depending upon the amp you are driving, or the preamp/amp and just turn it to max for that and control the volume with the preamp.
Sep 21, 2019 at 3:56 PM Post #1,790 of 2,153
okay i didn´t know that. Thank you.
So the Line out and Headphone out have their own Volume management?
Yes. You can set the LO to 100 and then what every you use for PO, say 40 and it will go to 40 and when you plug into LO, it will go to 100, while you are plugged into LO. Disconnect and it goes back to the PO setting.
Sep 25, 2019 at 4:33 AM Post #1,799 of 2,153
Why this new software isn’t on the www.ibasso.com in download section?
Firmware 2.9.121 is already on the iBasso website:
Sep 25, 2019 at 12:41 PM Post #1,800 of 2,153
I updated to the Lurker0 variant (from V2.4.59-L0) and everything went smoothly, as descriped in the instructions. No issues here.
One feature which I'm missing, is that the DX120 would remember the previous navigation after power off / power on. For example:
Navigate via directory mode to card 2/dir a/dir b/Artist/album
play
power off
power on
Now with a swipe to the left, I'm not in the album folder (as hoped), but again at the top level.
