iBasso DX120 pure DAP player. Balanced, single ended, line out and 2 micro SD slots. FW 2.9.21 now out!
Discussion in 'Portable Source Gear' started by Paul - iBasso, Aug 31, 2018.
Tags:
109 110 111 112 113 114 115 116 117 118
120 121 122 123 124
  1. magicalmouse
    Hi thank you for replying but i do have the one that came with it, what i need is to somehow attach the Mojo to the dx120 as the MOjo has a 3.5mm connection for the coax not a standard coax connection.
    d
  2. absolude
    Sounds good. Thank you.
    I have my strategy with FedEx and UPS but not sure it works with DHL.
    I call with the tracking number and request that they don't do any brokerage for me.
    Postal Services are better most of the time...
  3. absolude
    Hope I can avoid them. Worse case, I'll take my chances.
  4. PaganDL
    Hi all,
    Considering selling my hardly used DX 120, PM me for details & ONLY if interested.
    Hope you have a great day !
  5. bmnathe
    I upgraded from the DX80 to the DX120 today. I am running the DX120 on the most current firmware.
    The file scanning is a mess - a lot of albums are completely missing - and in some cases, multiple albums are combined into one big 'album' folder. This was not an issue with the DX80 - all albums were scanned/organized perfectly.
    ~90% of my files are from the same source (bandcamp) and in the same format (aiff).
    Is this a common problem that will be addressed with a firmware update? I am liking the sound and the balanced output - I do not want to return but it is annoying that I can only use the directory function.
  6. jamato8 Contributor
    You have checked and you are on the latest firmware? I would also do a factory reset.
  7. Rattle
    Try a factory reset, I know it sounds dumb and you shouldn't have to but after adding files to a card no matter what I did nothing else worked. Besides the screwy file scanning it's a great player. I have resorted to fixing all my flac albums and ripping them to single flacs instead of cue+flac and all album covers 900x900 max. Kind of a PITA but it all works now. Also you can just throw in the towel and use directory to browse the cards directly. No shame in that !
  8. bmnathe
    Yes, I am on the latest firmware and I applied a factory reset after updating.
  9. claudy
    you feeling what i'm suffers since this 2 last update FW. my files also lots of aiff that i ripped from cds.
  10. trivium911
    Hmm that is strange, the only time I had issues was when I didn't do a factory reset.
  11. bmnathe
    Should I revert back to the original firmware? Is this an issue with the newer firmware?
    JuanLuis91 likes this.
  12. JuanLuis91
    I think the most stable version is v2.5.68. It doesn't give me much trouble.
    claudy likes this.
  13. bmnathe
    I reverted to 2.4.59 and the issue is solved. I would not recommend using the newer firmware if you care about library tagging.
    Rattle, JuanLuis91 and vas-tomsk like this.
  14. claudy
    Just roll back to V 2.5.68, the sound come out from SE also more sweet to my ears than their before FW.
  15. expatriot
    I like things simple, so I kept my firmware at V2.4.56. I have had no problems at all, but I am curious as to the difference between it and V2.5.68?
120 121 122 123 124
