the wizard of oz
- Jan 13, 2007
Don't worry about VAT; labelled USB audio device, and low customs it shall be, closer to £20 in fact.
I suggest to:
1-reset to factory after installing 1.1
2-check that all songs are detected after reset
3-install 1.1.6
4-restart three times
5-do not reset and check files
6-insert sd
7-if this does not work, then reset in 1.1.6
8-see if the files are detected, by either internal and external memory, if not.......
A-get back to 1.1
B-sell your DX100.... But I really have no idea what and how my dx100 is behaving itself...
Try adding songs to your microSD....??So far no problems for me on 1.1.6... But then again, haven't used my DX100 much since updating.
Hi, did you have to ask them to lable it as that ?...also did it come with UK plug ?
dutycalculator.com is advising VAT at 20% has to be paid on £685.95, no import tax, this was on a usb audio device sub cat multimedia accessories.
