No, the D6 also has a higher supply voltage than the D12, about double. The higher voltage allows for the use of a greater selection of opamps if you are interested in rolling, and also more headroom for transients than is available in the D12. The D6 can be powered directly from the USB input without turning on the amp if you are using it as a stand-alone DAC, whereas the D12 needs to be powered on when using the DAC as a pass-through.
Thanks for the helpful info HiFlight, I am interested in rolling. I also like the fact the D6 can be powered directly via USB for DAC but will it charge from USB? I would like to avoid to carrying another charger when I'm traveling. I just had a look at the iBasso manual but I could not find any information on this.
It does not charge through USB, but can be powered through USB. The power is only 5v through USB compared to 12.6v on battery, so more powerful opamps like AD797's will not work as they need min 5v each to work.
The D4 might be a possibility for you, as the replaceable 9v batteries are available anywhere and still provide a decent output voltage swing. It can also be powered via USB as can the D6. It is easy to carry a couple of spare 9v batteries when travelling. You can also pick up pre-owned D4's fairly often on the F.S. forum.
Dual vs. single improves channel isolation, and in some circuits could possibly be used to create balanced DACs. However, if all your music is online streaming, you aren't going to benefit from this, per-se. However, should your source material improve, it's always nice to know your gear has more potential...
Make every day a fun day filled with music and friendship!
Stay updated on Dan Clark Audio at their sponsor profile on Head-Fi.
WARNING: BAD TRADER Also known as HeadphoneViking.
I realize this isn't entirely the right thread, but i saw someone here had the same problem with the D6, i just got a DB2 and PB2, and had them run completely out of power, now im charging them, the PB2 is fully charged, so the charge switch has been turned off, but its still plugged in. The DB2 is not fully charged, but i decided to use it anyways, but the white power indicator wont light up, no matter wether i unplug it, turn the charge switch on or off etc. Does anyone have any clue as to why this is happening?
I think I'm set on making this my first DAC and amp. I'm a newb and have never used anything other than my Air's headphone jack.
I plan to pick up some Grado RS2s soon and my laptop only has USB out. The fact this does 24/96 over USB and that it'll be an all-in-one combo that will be an amp as well has me excited.
MacBook Air --> D6 ---> RS2s
Then I can save up for a tube amp and then use the D6 as a DAC-only feeding the tube.
Ouch! I always hate reading about theft like that. I guess that means the RS2 will be under lock and key along with a few security guards when not in use?
