estreeter
- Jun 10, 2009
As a newbie to the world of portable hi-fi, I have a couple questions about this unit. The D6 is both an amp and DAC? All-in-one solution, where all I would need is a DAP? If I were to use this with an iPod, what would be the best connection? I would probably use it stock at first, then think about upgrading later.
Not sure if you are still a little confused here.
1. Using the D6 with a DAP, you will only be using the AMP section of the D6, either from the headphone out on your DAP or via an analog LOD cable (only available for certain DAPs from Apple, Sony etc)
2. To utilise the DAC component of the D6, you need to plug it into the USB port on a computer, select the D6 as your playback device, start your music player software (iTunes or whatever) and enjoy.
In short, when you plug the D6 into a DAP, you are listening to the musical stylings of the DAC in the player, not the D6 DAC.
