HiFlight
Yes, I did try running my HE-6 from the D6. With battery power, there is not a great deal of difference between it and my P4. Volume control is at about 2-3pm position for my normal listening level, but the sound is just fine, with full bass and no clipping. When using USB power, the SQ lacks weight and size and clipping is noticeable at normal listening levels.
While I do not own an HE-500 or LCD-2, there is no doubt in my mind that the D6 could drive them to any reasonable listening level when using battery power. (The Class A ISL55002 L/R module I am using in both the P4 and D6 outputs about 140ma) In the D6 I was using bypassed buffer and in the P4 I was using HA5002 buffers.
This caught my attention. Have you tried running the HE-6 with the D6 yet? Do you think it might provide enough power for the LCD2s or the HE-500s, knowing that they're less power hungry than the HE-6s.
