desertblues
- Feb 19, 2011
It does indeed have more power when you switch to battery while connected to USB!
It does, thanks again. (i actually discovered the manual which answered one of the questions). If do i risk damaging my speakers/amp or headphones if the battery gets too low while playing? I'd assume not.
Hey Guys! Got my D6 yesterday! i have some questions (my very first amp/dac), and i apologize if they're kinda silly.
1) When using as a combo through USB, im able to change the volume in Media Player, the volume of the laptop and the D6 itself, of course. Is this how it should be? for some reason, i thought that when plugged into USB i could regulate the volume only from D6.
2) Within the first 4 hours of listening i had very loud static noise two times. Terrible experience i should say. i saw on this thread that some people had this problem as well from time to time. But i had 2 since the very beginning, should i be worrying that i might have a defective unit? have anyone found a solution to this problem? (my OS is Windows Vista 32bit).
Thanks.
Make every day a fun day filled with music and friendship!
Stay updated on Dan Clark Audio at their sponsor profile on Head-Fi.
No promise, but there's a least a good probability it's noise from a phone or wifi being picked up by the D6.
iBasso's stock op-amps are somewhate susceptible to RFI. Keep your Blackberry in another building (or at least 4-5 feet away), most other mobile phones at least 3 feet, and consider if you are using wifi, maybe using a longer USB cable to get the D6 away from the PC.
TopFlight has posted some comments about opamps that are less RFI sensitive.
Just ordered my D6
How long does it usually take to get it?
China | 07/18/2011 | 3:51 P.M. | Order Processed: Ready for UPS |
