- Aug 9, 2006
Probably be picking one up myself! Not stock, but I will decide today about it... nervous...
Originally Posted by Anouk /img/forum/go_quote.gif Hello everyone, I got my ie8 today and so I can now try my d4 and d10 both with topkit. I must say so far I prefer the d10 with the ie8. The d4 sounds a bit warmer and more laidback imho but since the ie8 already has those two characteristics its a bit much. AlsoI have to be VERY careful witht he d4s volume or there will be lcipping on some tracks. I must say the d4 does seem to have a bit more space around the notes, so a bit better imaging but the ie8 already is a soundstage king so I do not mind missing this with the d10. The d10 does seem to hiss a bit more but it goes away with low gain. Greetings, Anouk, |
Originally Posted by LionPlushie /img/forum/go_quote.gif Just go ahead and get it By the way you're from Korea? |
Originally Posted by shigzeo /img/forum/go_quote.gif I'm not from Korea, I am in Korea for a stint. Mostly likely, I will be buying Anouk's D4 - we shall see. I don't like to buy non-stock products, but we shall see. |
Originally Posted by jamato8 /img/forum/go_quote.gif I would bet that it doesn't have a recharging circuit because of the knurled fittings on the back. I like using the low discharge 9 volts though because they provide a better sound and then there is the 500mA liPoly or alkaline or lithium for the longer run. |
Originally Posted by LionPlushie /img/forum/go_quote.gif it really make a difference using the low discharge tysonic 9v? cause the previous exchange of replies with larry on this thread, implies that it doesn't matter. and i should be on a lookout for higher capacity 9v, the li-ion ones. |
Originally Posted by LionPlushie /img/forum/go_quote.gif Which part of his is non-stock? I wonder how Ron modify his. |
Originally Posted by shigzeo /img/forum/go_quote.gif It could just be that the line out from the iPod doesn't deliver the same input levels as the DAC does. |
Originally Posted by madwolf /img/forum/go_quote.gif I am very sorry to hear that you broke the cap, But since it is connected between the output and negative input it should be a compensation cap likely 47pF only. If it act as a filter at max it is 1nF. Adding a .1uF or a 0.01uF with make this to a low pass filter. Not advisable. If I have a D4 I could desolder and measure with a capacitance meter. If iBasso didn't give you an answer let me know, I see if I could borrow a D4. and measure. |
