The D-Zero has about 80 hour of burn-in and I will be doing more in-depth listening tomorrow, mostly as a portable amp fed from an iPod 5.5 modified to accept the 240 Gb HD. I will use the iBasso D4 and the Leckerton Audio UHA4 (w/ 8610 op-amps) for comparison.
In the last 3.5 days of using the D-Zero I have developed some opinions;
1. The small size and low weight of the D-Zero are very welcome features outclassing the other two units.
2. The D-Zero and the UHA4 have the very convenient feature of charging via the USB. All three units use the USB as the signal input or via the 1.8" mini.
3. Although the iBasso D4 does not allow charging via USB you can use it power and feed the D4 thus prolonging the life of the 9 Volt battery.
4. Of the three the iBasso D4 allows the user to roll op-amps, if you want this feature the Leckerton Audio UHA6 also allows it.
5. Both the iBasso D4 and D-Zero feature a DAC line level out via a 1/8" plug in the front, which also doubles as the analog input. If this is an important feature, well ...
6. The volume pot on the UHA4 is my favorite, just love being able to go up/down (2 dB) with a flick. BTW, the mute feature built into the volume pot is a great one to have.
7. All three units sport a gain switch.
8. The battery will last about 24 hours with the UHA4 and 30 hours with the D-Zero. Runtime on the D4 will depend on the type of battery (NiCad, nMh, lithium, etc) and op-amps/buffers used.
Of course all of the above are just the icing on the cake, the proof is on the sound. Should have more information tomorrow afternoon.
