iBasso Boomslang DB-1 & DB-2 and Toucan balanced portable dac and amp . pg 1, 19 , 25, 26 . . . .
Jul 8, 2010 at 4:11 AM Post #61 of 612
Yes and no.....  Pins always go into their respective numbered partner...for example, male pin 1 goes into female receptacle 1 etc, but keep in mind that they face one another.  The numbering will *appear* to be reversed when looking at them each head-on.
You will notice that male plugs are numbered on the rear while females are numbered on the face.  If you wire according to the printed numbers on each, you will be correct.
Ron
I must be looking at the wrong way then.
Jul 8, 2010 at 10:26 AM Post #62 of 612
This is obviously a noob question.. But I just bought my HIFIMAN HM801, and how do I access its digital out? (PS, though it's bigger than the iRiver so even if I figure this out I might just use my iRiver..)
As far as I'm aware it does not have digital out, one of the points being that it incorporates a superior dac from the start
Jul 8, 2010 at 12:56 PM Post #63 of 612
You're right its a coax-IN not OUT. For some reason I've always believed it got a digital out.
Jul 10, 2010 at 1:15 PM Post #64 of 612
I ordered and have a Toucan winging its way here. I will be on the road, as I am moving to Pohnpei, Micronesia but will have full mail service there and email (I hope). The amp I will have before I leave Monday after this coming Monday.
Jul 12, 2010 at 1:09 AM Post #70 of 612
an adapter would (most likely) not work because a mini jack utilizes a shared ground, whereas the point of balanced is that it has indepedent active grounds per channel.
if your cable had an indepdent ground and lead per channel (4 seperate wires), you can just reterminate the cable into a balanced connector. if the cable utilizes a share ground (Left Channel, Right Channel, Common Ground) then a recable would be necessary
