Kerouac
i dont think removing the mesh filter, on the nozzle if that is what ur referring to, will make any difference. i have tried that before, i lost the filter on the right, with no other option i just remove the left part. i used this fpr motre than a week and dont find any difference at all.. i returned it only when i found the lost filter in one of my eartips..
Unlike the fellow above, I notice better definition in the higher frequencies, better micro-detailing, a cleaner sound. At the expense of some (not much) bass.
It's easily reversible, if you remove them gently. Not recommended though. Do this at your own risk.
OK, thanks for the replies!
I might (not entirely sure yet) give it a try later on
