bogi
- Mar 16, 2013
You can reach everything you want in HQPlayer environment. You don't need to switch between Roon output and HQPlayer output.The Roon is set so I can choose in the bottom right of the screen either my Holo Spring 3 DAC (for NOS) or HQ Player (which would oversample and then send the signal to the Spring 3 DAC). Usually when I use the Spring 3 option for NOS in Roon, and then change Roon to HQ Player, I have to close out of Roon and HQ Player, and restart them before I can use HQ Player correctly.
You can use HQPlayer Client to switch output sample rate or to switch between PCM and DSD output.
You may look at these 8 pages to get idea what are optimal settings for Spring: https://audiophilestyle.com/forums/...-dac-r2r-dsd512/page/5/?do=userPosts&mid=4870
