HQPlayer Impressions and Settings Rolling Thread
Jan 5, 2024 at 10:43 PM Post #376 of 2,436
Poly sinc gauss long for 1x and poly sinc gauss hi res lp for nx are the base filters recommended by the developer. Now whether you can do 1024 will depend on your compute. Using a lower such as 256 or 512 with an EC modulator will likely achieve “better” results.
Jan 5, 2024 at 10:47 PM Post #377 of 2,436
EC modulator? As in DSD5EC, ASDM5EC-super, etc? Any specifically?
I have an i7-13700k and a rtx4090.
Jan 5, 2024 at 10:51 PM Post #378 of 2,436
Jan 5, 2024 at 10:52 PM Post #379 of 2,436
Jan 6, 2024 at 3:15 AM Post #380 of 2,436
What is the benefit of using a Holo Red, rather than just streaming the music from a computer through USB to the Holo Spring 3?
Your HQPlayer computer and your DAC can then appear at distant locations, even in different rooms. You can use one HQPlayer computer to play to different NAAs in different rooms (not at once).
Holo Red in NAA role can be used also to provide isolation from noise generated by HQPlayer computer. That's helpful for DACs which don't provide higher level of galvanic or EMI isolation on their USB input (maybe Spring 3 does not need that).
Jan 6, 2024 at 3:45 AM Post #381 of 2,436
From the client I only see local host and no qobuz option.
You need to swipe to Album view. HQPlayer manual (installed with the application) chapter 8.1:
Then in Album view:
Jan 7, 2024 at 7:07 PM Post #382 of 2,436
To run HQPlayer through a Holo Red, do you have to physically connect a separate computer that is running HQPlayer to the Holo Red? Or can it all be done wirelessly?
Jan 7, 2024 at 7:42 PM Post #383 of 2,436
Wirelessly as Red will be identified as NAA by HQPlayer
Jan 7, 2024 at 8:13 PM Post #385 of 2,436
So you don't have to plug the Holo Red into anything other than your DAC? HQPlayer and your music streaming all connect to Holo Red wirelessly? Does Holo Red put out a wifi hotspot to do that?
Red will be connected to your network via LAN Ethernet. Your laptop will be on same network and hence will see Red as appropriate endpoint based in playback software you use. If you use Roon then it will see Red as Roon ready endpoint, HQPlayer will see it as NAA or software like Audirvāna will see it as UPnP endpoint.
Jan 7, 2024 at 8:17 PM Post #386 of 2,436
So you have to connect the Holo Red to your router via an ethernet cable, but the computer that is streaming music from Roon or HQPlayer to the Holo Red can do that wirelessly, without ethernet?
Jan 7, 2024 at 8:18 PM Post #387 of 2,436
Yes, that’s correct
Jan 7, 2024 at 8:23 PM Post #389 of 2,436
Does the Holo Red do any processing for HQPlayer? Or does 100% of the HQPlayer processing happen on the computer you are using to stream to the Holo Red?
All processing of HqPlayer will be done in your desktop or laptop.
Apart from streamer, I guess, Red can also act as DDC i.e you can connect laptop to Red via USB cable as well. So you can use Red as streamer via LAN or can use as DDC connected to laptop via USB.
Jan 7, 2024 at 8:24 PM Post #390 of 2,436
Do you think Holo Red is worth it if you have a Holo May or Holo Spring 3 that has galvanic isolation and so no need for a DDC?
