Feb 24, 2018 at 8:16 PM Post #46 of 49
A Anker battery would probably double or at least half the time of the amp.
Feb 24, 2018 at 8:46 PM Post #48 of 49
Answer 1) Sorry but what's the rig or rig bottom? I have the DAP pushed up towards the connectors usually but I don't want to do that because otherwise the indicators get covered. I don't know if I got what you meant, wrong . Do you mean rotate it and make it landscape??
I mean put your setup on its side instead of using the A5 flat side at the bottom. Also if you setup the A5 the correct way around, you can have it so that the battery power lights are not covered.
Answer 2) Again, I don't know what the rig is :/ sorry lol. How would I connect the battery to make the amp last longer? Would it be charging the amp whilst I'm using it? Sorry, I'm not very technical lol. And what mAh version of it is the best? Could you link me to one please?
Anker PowerCore+ mini (3350mAh Premium Aluminum Portable Charger) Lipstick-Sized External Battery Power Bank for iPhone 6 / 6 Plus, iPad Air 2 / mini https://www.amazon.com/dp/B005QI1A8C?ref=yo_pop_ma_swf
Feb 24, 2018 at 9:01 PM Post #49 of 49
Whoaaa that's a lotta wires and stuff lol.
Ohh I see. I was just holding it to show people what I meant but I was on about when I take it outside. Then, it's in my pocket and when I take it out to I can't see the battery indicators and it died because I didn't know it was dying lol. I can put the bands in the middle like you have but then the screen gets covered and not to mention the Plenue Ds buttons are on the side makes it hard to press.
Ah, I've got an "EE lipstick" battery charger like that, doesn't even do one charge whilst am using the amp or back then my Plenue M. So is this different or lasts longer or something? Because it's only 3500mAh. Also, how does it "add 10+ hours" to my amp if all it does is recharges it? Also, won't that mess up the amps battery? Sorry, just want to be thorough. Oh and the link didn't work, so I just Amazon searched it, thanks though!
