Feb 8, 2015 at 7:11 AM Post #1,021 of 1,153
I've been doing this for years and I can't envisage any way of programming this approach to work with one click without user feedback. That said I do have canned presets for a lot of headphones--is that what you want? But the results are going to be a far cry from optimizing a pair of phones for your own ears.
i will appreciate if u can send me some presets
i listen most to synthpop, metal, rock, indie, ambient music
i am so curious to see what u have achieved, i might use urs as startup points and then continue tweaking
my headphones are ooze lcd2 rev2, and i use ifi dsd and jriver on windows
Unfortunately I have never set ears on these phones.
Feb 15, 2015 at 3:12 PM Post #1,023 of 1,153
  Can anyone recommend a very good hardware parametric equalizer???
Please!
I use Technics SH-9010. 5 band parametric EQ.
http://www.thevintageknob.org/technics-SH-9010.html
If you really want to go crazy, there is VERY seldom SH-9090 for sale
http://www.thevintageknob.org/technics-SH-9090P.html
- but do not forget - you need TWO. These puppies are extremely costly ... a pair currently on ebay :
http://www.ebay.com/itm/261600461238?rmvSB=true
Feb 15, 2015 at 5:31 PM Post #1,024 of 1,153
Feb 15, 2015 at 5:39 PM Post #1,025 of 1,153
Digital or analogue? Only the former is worth considering, imo.
Oh no, not AGAIN.
What is the difference between a virtual EQ with conjuction with computer and "digital EQ" - none of them would make the grade of "hardware" in my book.
If the frequency of the headphone is so jagged to require more than what analog EQs listed above offer, than the headphone should be replaced with a more reasonable model. No headphone that is considered good should not require more.
Feb 16, 2015 at 4:06 AM Post #1,027 of 1,153
It's not parametric but it works for me and can be used as a parametric EQ with a little extra work, and it is digital (which puts noise into the power line that must be dealt with).  The 60L DEQ has some nice features that I use all the time.
http://www.rane.com/deq60l.html
Thanks Rico613! It puts noise in the power line? How do you deal with it?
Feb 16, 2015 at 4:09 AM Post #1,028 of 1,153
Thanks Analogsurviver
I am seeing either inexpensive units that are likely not going to be great sounding-or EXTREMELY expensive units costing multiple thousands. Most these days are for DJ's and PA systems-not audio. I have a very common rolled off high and upper mid type of loss that would be easy to counter with an EQ. The fancy Room EQ will not take that into account.
Feb 16, 2015 at 4:15 AM Post #1,029 of 1,153
You welcome Exacoustatowner ! ( What happened ? with Acoustat ) SH-9010 - if you are prepared to wait and thus shop carefully, is something in between the two options mentioned by you - can be had for say $200-300. It does come handy if you can refurbish it yourself or know someone who will do it for reasonable amount - it is nearly 40 years old and given some TLC, will still be going strong.
Feb 16, 2015 at 8:03 AM Post #1,030 of 1,153
I'm using Shunyata DPC-6 power distributor.  It is designed specifically for noisy digital components such as computers, cd transports, DAC's, etc.  I found that the DPC-6 makes a profound improvement to overall sound quality.
http://www.shunyata.com/our-products/pwr-dist/48-power-dist-ref-series/303-dpc-6#!hydradpc6_rear
Check out the videos for the DPC-6
http://www.shunyata.com/technical-feat/videos-gallery
Feb 16, 2015 at 3:43 PM Post #1,031 of 1,153
Thanks Rico!
Feb 16, 2015 at 10:19 PM Post #1,032 of 1,153
  Oh no, not AGAIN.
Only holds if you don't have hearing loss-in which case...
Feb 16, 2015 at 10:40 PM Post #1,033 of 1,153
I'll keep my eyes open for the SH-9010! As far as why I dubbed myself Ex-Acoustatowner- long ago I foolishly allowed someone's very reasonable argument that they were too big for the room I had to get me to sell them for more reasonably sized speakers.
They had AMAZING sound that I never quite recaptured.
Feb 18, 2015 at 3:45 AM Post #1,034 of 1,153
You can always tame excess bass power and resonance with room treatment and EQ, besides, tinny speakers will never reach low enough in any room.
Are you sure you need an external EQ? Most of us here do fine with parametric EQ plugins on the computer ;)
Feb 18, 2015 at 11:00 PM Post #1,035 of 1,153
Hi Joe
I am trying to correct for my own rather steep roll off in the higher frequencies due to hearing loss-and am using CD and or SACD's as source-not a computer-but that would be a great way to go otherwise. I have room EQ for my speakers already. It does not help with my own roll off.
