Originally Posted by Br777 /img/forum/go_quote.gif
please bear with me
so you need a special type of mic for this?
Yes, you need a microphone with a very flat frequency response, and a real time analaiser. I guess I was blessed in that I had been looking for the DEQ2496 for a while, and a set of the DEQ2496 and microphone (and the sample rate converter box, which is the definition of overkill for my system) came up for sale exactly when I had the money.
if so can you tell me what kind i need |
I have the behringer microphone, their model number for it is:
ECM8000
You could probably use other measurement microphones, but theirs is not terribly expensive and works well enough. I know other people go to great lengths to assure the accuracy of their microphones. I didnt do that.
does it matter where you place the mic - im assuming you have to put it in between the headphones and your head? |
This is where I do things in a way that is totally "wrong" but until now has worked for me.
I have a piece of cardboard about 4" square with a hole sized for the microphone in the middle (the microphone is only about 1/2" diameter) and put that whole mess up to the headphones. Be careful not to put your hand behind open drivers it really screws up the frequency response (try it deliberately if you have a moment.) Then I run white noise through the headphones and observe the sound on the RTA. After that its a simple matter of flattening things out with the various equalizers.
so were you saying that you felt this method was as accurate as simply eqing out the peaks by ear? |
I like measuring "OK" although with only a few days of using the method in the OP Im becoming less a fan of measuring and more a fan of tuning by ear... Its me that listens to music, not my microphone after all. Although I EQ'd several of my headphones flat based on the microphone I had not used it much because to my ear it caused a weird coloration in the highs. The flip side was that on many albums & pieces it brough everything into clearer focus but it all acquired a "papery" for lack of a better word. There was texture, but it was painted on paper...
EQ'ing by ear on the other hand brings the music into focus better, but still retains more subtle textures which GREATLY increases my enjoyment of the music. I guess time will tell if I stick with this, but so far its a change for the better.
Originally Posted by gilency /img/forum/go_quote.gif
I am glad to hear somebody else enjoys the DEQ2496. I love its parametric equalizer and have used it to equalize my Stax Sigma Pro.
It really sounds much better with equalization.
Yes, the DEQ2496 is sweet. It came well recommended by a few other headphone palls and is very reasonably priced even for just a DAC.
Stax actually made a parametric EQ for their headphones (the best guess is it was parametric, like many things in the history of STAX the exact nature of it is somewhat mysterious). I had one with my lambda pro rig, it was a very neat device.
