Originally Posted by
purrin /img/forum/go_quote.gif
You can modify SR60/80s to make them sound better, but it's doubtful you can make them "sound like or have the detail level of a SR325." You can't just clean up a driver that sounds inherently more "dirty" to the extent necessary with new cups, silver wiring, dampening, pads, etc. Maybe a new voice coil made of less resistive wiring with more windings would to the trick though.
You can definitely make them sound better and some of these mods - like venting the drivers, damping the backplate and removing the grill cloth, along with the plastic grill and back button - cost less than $5 and present no danger to the drivers at all.
With respect to cleaning up "a driver that sounds inherently more 'dirty'," I'm not sure the driver is dirty to begin with. To be sure, the diaphragm is made of plastic film (Mylar), suspended on a plastic basket, but so are all of the other Grados. I see no evidence the film is any different in diameter or thickness. I see no evidence that the magnet is any different, either in size or magnetic force. The only internal difference I can talk about is the use of UHPLC copper in the voice coil versus standard copper. As the voice coils are identical in size, employing the same gauge of wire, the only difference there could be is in the inherent conductive difference between UHPLC copper and standard copper.
So what is UHPLC copper? Google it and you will get 4,920 results. I'd like to tell you that I clicked on every one of those results but who has the time? I did, however, scroll through the first 100. Guess how many tracked back to Grado? Take a wild guess. The answer is 97. A company called Millipore sells fittings for a UHPLC filtration system. So does Kinesis USA. So does an outfit called Idex: Health & Science. So, unless I'm missing something, this UHPLC wire is just a name Grado gives to its wire. I don't see any other headphone maker using UHPLC copper wire. The term has no meaning outside of Grado Labs. It is a marketing ploy.
The good news is that there are actual terms, used in the industry, such as OFC (oxygen-free copper) and OFHC (oxygen free high thermal conductivity). While OFHC is used in cryogenics, OFC gets used in audio. The ASTM International sets international standards for an exhaustive list of materials, including copper. Of the many compositions that can be called "copper," there are three that apply here:
C11000 or ETP (Electrolytic Tough Pitch). It's the wire you see in just about everything. It's not "oxygen free." It's 99.9% pure, with an oxygen content of .02 to .04%. This wire conducts just fine. In fact, it meets 101% of the IACS standard. It has a conductivity rating of 100%.
C10200 or Oxygen-Free Copper (OF). Despite the name "oxygen free," it's not. It simply meets a threshold of 99.95% purity, with an oxygen content of .001%. It has the same conductivity rating as ETP. For purposes of purity, silver is counted as copper (since it has a higher conductivity).
C10100 or Oxygen-Free Electronic (OFE). Despite its name, this copper isn't oxygen-free either. It simply meets the highest threshold of 99.99% purity, with an oxygen content of .0005%. It has the same conductivity rating as the other two, but it's the closest thing to pure-pure as you're going to get. Because of the extra hurdles in processing, it's the most expensive.
Grado doesn't say its copper is OFE, which means it probably isn't. That's okay, however, since it really doesn't matter. You're not buying a voice coil for the copper. You're buying it for the conductivity, which is 100% across all three. I see no evidence that "UHPLC" copper provides any audible difference in sound. Nor does listening to different headphones, constructing different environments around the drivers, really say anything about the sound difference in using one form of copper over another. Since Grado doesn't use a standard recognized by anybody else, there's no way to really know what, exactly, Grado is selling as wire. Even if it were the more expensive OFE (which it would then be able to market at such), it's hard to imagine that a difference in purity of less than eight-hundredths of 1% would make an audible difference.
Furthermore, if this is what we're calling a "dirty driver," when Grado's "matching driver" standard for the 325 is .05 dB, I have to wonder whether these "details" missing in one headphone and showing up in another aren't byproducts of the environment in which they're being placed. There is far more difference between the plastic, mahogany and aluminum housings than there is between a voice coil made from ETP and one made from OF or OFE. Nor should this be a construed as a criticism of Grado's wire, which is every bit as good as everybody else's.
Go back to that first episode of the first season of Mad Men. Why is the tobacco in our brand of cigarettes any better. "Because it's toasted." But isn't everybody's? "No, theirs will kill you. Ours is toasted."
What would be the mod to accomplish this?" There is no one "mod" or even simple set of mods to do this assuming that it's possible. What you are talking about is a complete reconstruction of the headphone. I beseech you!
Do not send others down your path of madness!!!
THIS!!
IS!!!!!!
SPARTA!!!!!!!
![](https://www.head-fi.org/attachments/83614/)
