Originally Posted by Shike /img/forum/go_quote.gif
You're making it sound like I assume all amps sound the same - regardless of anything.
Yes, I did. But that was just a working hypothesis to have a starting point. You have the opportunity to correct it anytime.
Evidence? Or are you a hundred percent assuming too? |
100% assuming, too. I take it from the reviews I've read about the good synergy between HeadRoom amps and the 300-Ω Sennheisers. So I'm indeed 100% sure that HeadRoom amps can drive 300-Ω headphones. And 600-Ω headphones as well.
An exotic? Hardly . . . have you not heard of AMB Labs? The Mini^3 only goes to 300ohms, while the M^3 is much more capable. |
No, I don't know this company, but I've heard of the M^3. The Mini^3 apparently is an exception among headphone amps. A budget model, as it seems?
Not all amps are equivalent or made for all loads. On the other hand I don't think it's particularly expensive accomplishing good amp design either, and gets blown out of proportion too. |
I can't speak for amp designs in detail, but I think it's easy to build a headphone amp that measures perfect. And still I don't agree on the criticalness of impedance matching. I don't know one single solid-state amp with impedance restrictions. Even if we accept this exceptional case, the call still stands that with solid-state amps you (usually) don't have to care for headphone impedances. And any sonic mismatches are unlikely to be caused by such problems.
That's rather vague - in terms of a question. The numbers they provide only tell so much. What's the THD of the amp at 16ohms and 650ohms? Are we to assume it's impervious to different loads for no reason? |
Not at all. But these HeadRoom specs are in line with other solid-state amps, and since they offer a near-perfect picture, deviations from them towards different load impedances won't destroy it. Not in headphone amps. Even if the THD is increased by a factor of 3 at low impedances (which is a realistic scenario) it is still way below audibility*. As mentioned, I have access to many measuring results, and among solid-state amps they're definitely no evaluation criterion, since frequency responses are linear enough, distortion figures low enough to be inaudible by a large margin – at least *according to established psychoacoustics.
I'm not implying anything unlike you. I hope Headroom wouldn't sabotage one of their own products to create an artificial tier. Again though, I'm not going to assume one way or the other like you seem to. |
Combine your statements («I don't think it's particularly expensive accomplishing good amp design either, and gets blown out of proportion too» ... «all of the amps I've purchased meet the needs of my headphones, so I really can't tell a difference») with the manufacturer specs at hand, and it would be a logical assumption from your part that all HeadRoom desktop amps will most likely sound the same. Yet you're desperately trying to obfuscate this self-evident possibility. I don't have to tell you why.
You keep saying "I'm sure", but you haven't even touched one. They may be great amps, but headroom doesn't provide enough information for anyone to be sure. |
You know, «I'm sure» means: «I'm not 100% sure, but I think...». I get this impression from the multitude of positive reviews. That's where our approaches differ fundamentally: I don't rely on specs (as they tell nothing in the context of headphone amps – see above), but rather on reviews and of course personal audition.
This excursion to amplifiers actually served for demonstrating that cables and electronics can be treated equally when it comes to measuring data (although they still differ by one or two magnitudes): If properly designed and made, they don't show significant* differences. This also applies to the reported blind-test results. In this forum corner you'll find several proponents of the «all amps sound the same» philosophy. You belong to them yourself in my book, despite your reservations.
My point is that if you think all cables sound the same, because the measured differences are too small to be audible, you also have to think that more or less all (solid-state) amps sound the same – for the very same reason. This based on established hearing-threshold figures. (
Nick Charles is an expert in this field. Maybe he will help us out with this.)
My point behind the point is that I don't take established hearing-threshold paradigms as seriously as some. There's more to be discovered in audio electronics and psychoacoustics than commonly accepted (or rather: ...whereas many think there's nothing more to be discovered at all). That's why I can live with the «cable-sound mystery».
