[1] So are you saying that different headphone brands and models, as long as they’re high fidelity, won’t consistently produce a different size/depth of soundstage amongst one another because the speakers are too close to the ears?
[1a] So something like the Focal Utopia will cast the same soundstage depth as the Sennheiser 800/800S?
I can't speak for what bigshot meant but I'd like to answer this question anyway.
1. I am saying that no headphones, regardless of brands, models or fidelity, produce (reproduce) any soundstage at all! All headphones (and speakers) do is reproduce two audio signals simultaneously (left/right audio channels), that's it, nothing more, there is no soundstage. Soundstage isn't "produced" by HPs, it's entirely produced by the brain, it's an illusion, the result of the brain trying to make sense of the sensory input data. This sub-conscious calculation therefore has two parts, the sensory input data itself AND, what each individual's brain considers "make sense" to be/mean. In other words, the brain effectively takes the sensory input data (IE. From two eyes and two ears) analyses, correlates and compares it, and cross-references all this with a life-time's worth of memories/experience to create a resultant "image" (perception), which is effectively a best guess of "reality". There are a large number of variables at play here, for example, just the analysis of the input data from the two ears includes (amongst other things) identifying what are direct sounds within the signals and what are reflections, the relative level balance, phase/time and FR of both, comparing the input data from each ear and referencing all that against a life-time's worth of experience of real acoustic spaces. It's also worth noting that we're talking about the data input to the brain from each ear, not the actual sound entering the ears and this input data is different for each person because our ears are not all exactly the same distance apart (therefore the phase/timing is different) and we all have somewhat different pinnae, hearing and listening skills, each of which affects the FR of the data the brain then uses for it's "best guess"/"image"/"perception". Therefore ...
1a. Neither the Focal Utopia nor the Senn 800/800S cast ANY soundstage depth. However, they do have differences in FR, differences in driver distances (and therefore timing) from the ears and also differences in other input data (not just from the ears!), which in turn can have an effect on the final perception (of soundstage). Whether these differences do affect one's perception of soundstage and if they do, in what way and by how much, is dependant on each individual's perception ("best guess").
[1] So I learned more about measurements, and yet I am still trying to pin down certain measured effects, like the effects of soundstage depth in measurements.
[2] I currently can manipulate this to a degree, but not fully control it yet.
1. For the reasons just explained, you'll never "pin down" soundstage depth from measurements of the sound output by your HPs because soundstage depth is not a property of sound, it's a result of perception and therefore, the measurement you'd need is a measurement of perception rather than sound. Such a measurement doesn't exist and even if it did, could/would be somewhat different for each person. Therefore ....
2. That's because you can only manipulate certain variables which can affect the perception of soundstage depth. If you're the one creating the music mix you can manipulate far more variables and to a greater extent but even then, it's still ultimately a perception, so you can only ever have some (rather than "full") control of it, some of the time, for some people. In other words, even if you achieve "full control" just from manipulating the output sound, it will only work for some, few or no others and even just for yourself, it may or may not work at a different point in time as other variables change. For example, if you use different headphones and/or, as your hearing, listening abilities, experience and perception biases all evolve over time.
G
