obzilla
Thanks @OneEyedHito and @koso , I think you guys are right. This is in the spring 2 page, and not totally clear if it’s part of the old 2 info, or them talking about the then-upcoming 3. Sounds like it’s the latter. Cheers!
![1679040651642.png 1679040651642.png](https://cdn.head-fi.org/a/12014492.png)
That Kitsune badge is something else isn't it? Congrats!This showed up a few minutes ago!
Not gonna lie, i also went for that version because i wanted the fox logo. Maybe even more than the enhanced USB modul ahaha.That Kitsune badge is something else isn't it?
I am using GoldenSound's config, PCM, 1.5 million taps, it takes up about 58% CPU on the Beelink 5600H, I use NOS mostly but when I need it to be more incisive and attacking his HQPlayer setting work well.
https://drive.google.com/drive/u/0/...mY-4ct2IZMJX4jY81vZlkaNitU0?usp=sharing&pli=1
https://www.signalyst.com/consumer.htmlCan HQPlayer be used with any streaming app? I'm using a Chinese streaming app on MacBook Pro.
I also read HQPlayer can act as an endpoint to Roon so it should be possible theoretically, but I also don't have Roon so can't confirm.Can HQPlayer be used with any streaming app? I'm using a Chinese streaming app on MacBook Pro.
Hi, yes you can use Roon with HQPlayer. I had this setup in my system and it works.I also read HQPlayer can act as an endpoint to Roon so it should be possible theoretically, but I also don't have Roon so can't confirm.
Have you already published a comparison of V550 and Bliss?
He's in the wrong thread. Get those forks out@DMITRIY R This is the Holo DAC thread, likely better luck in the Bliss thread specifically.
Bliss Thread
No i don't have, Bliss is already since yesterday here, i need more time for a result!Have you already published a comparison of V550 and Bliss?
It is very interesting what differences they have and which one you give preference to?
