fermelom
- Feb 17, 2011
It comes on top of the balanced amp. I have made an official inquiry about it. If I had to guess its just that if you switch regular headphones to IEM and forget to change the volume, you can overdrive and damage the IEMs.
Other than that, I don't buy the rest of the theories above.
The photo shows the polarity of the trrs conector used by HiFiMAN.
Then, completely plugged we had this disgram:
R-/R-
L-/L-
R+/R+
L+/L+
At the fist step of unplugging we had:
R-/L-
L-/R+
R+/L+
L+
At the second step of unplugging we had:
R-/R+
L-/L+
R+
L+
At the third, and last, step of unplugging we had:
R-/L+
L-
R+
L+
Well, I'm not expert but the second step of unplugging looks to me like a short circuit. This is what I think the warning means about not plug or unplug headphones with the HM901 on while using the balanced card in balanced mode, cos you csn cause a short circuit and damage your headphones.
