reddragon
- Dec 23, 2011
didnt know that, and im comfortable with the side buttons anyway, no point of using the slide bars since it sounds so troublesome
You can also adjust the volume with the screen on. That is only possible though once you've activated the volume control and then you attempt to manually raise or lower it. I do find it useful though when you want to raise or lower the volume on the fly but you should be careful though.
