kob12
- Dec 31, 2011
KT66 can You compare studio 3 to hm-801 in terms of sound quality ,bass response and soundstage ?
As you're new to this game I have just one to add - impedance and hiss are not related. I have the Tzar 90 (90 Ohm) and they hiss out of pretty much anything. I'm sure they'd be unlistenable with the Studio V, which is known to hiss...
Much obliged!
I guess it's just been my experience that a headphone's impedance level makes a significant difference to the sensitivity at higher frequencies. That being said I haven't really played with any high-impedance headphones, so that may have broken that correlation for me a long time ago.
How are you enjoying the Tzar 90s anyway? The 4.Ais are quite nice, but definitely the most sparkling presentation I've come across in an IEM so they're taking some getting used to. I'm switching out the tips to comply Tsx-500 (once they arrive in the mail). Hopefully the added isolation will let me bring the levels down and not get fatigued so quickly.
btw, I'm not particularly 'new' to the game - been messing with audio gear for more than a dozen years now...and trolling this site on and off since then. Made my first online headphone purchasing decision back in 1999/2000 based off this site: Grado SR-125...those were the days
801 is much better in every way, except for size,build quality and battery life, but at over twice the price it should be.
I don't think its a fair comparison. Comparing to 601 or 700 would be better.
Connect to your PC, find it as a drive in 'My Computer' and toss the contents of the system folder. If that works, it's likely something you did.
Did you follow the procedure in the manual for "frozen" player? page 48
There is also a second set of steps to take in the "Basic Functions" section of the manual that might help. Page 38
Gignac said:I brought it into work with me to fiddle with, but I didn't bring in the manual - I recall reading through that the last time this happened - something like reset, middle button, wait 30 seconds, middle button again?
Anyhow, I'll keep playing around with it and who knows, maybe another miracle will come my way. I'll contact Jack again regarding a repair should all else fail, but I'm really considering just picking up a used AK100 or something.
I really love this player when it works, but this last issue has put enough doubt into me to consider other options.
Sad face.
Here is the text from the manual. maybe this will help?
So, here's the closest thing to any recognition of this player as a device since this morning:
While plugging it into a USB port does nothing (to the computer, nothing has happened), when plugging it in while holding the up arrow, I will get this from my PC:
"One of the USB devices attached to this computer has malfunctioned, and Windows does not recognize it..."
Doing the same using my macbook does nothing.
I've contacted Jack for a repair.
Just for S&G, have you tried plugging it into an AC adapter and just leaving it for a few hours? Not the USB on the computer but a wall charger.
