jmills8
Previously known as bmiamihk, jmills2
He did not say that. He is focusing if a thin cable to a thicker cable sound different.
Thanks for the feedback. Sure doesn't make the search for an upgrade cable any easier though lol...
So... a cable upgrade won't be noticeable with an IEM in general? Even one like the Vega? Or is it that the type of cable will make more of a difference than the thickness or wire count?
I'm kind of confused with the higher range of OC cable range. Could someone explain what are the materials used for Grace 2 and OC AU X?
Hence why I asked if what he was saying is that the cable type makes more of a difference than the thickness or count.He did not say that. He is focusing if a thin cable to a thicker cable sound different.
