I have heard the EE odin and the stock cable, the Storm breaker is some how too aggressive in the upper frequency but lack of density and extension in the lower range.Cardas Clear Light.
It is the same thickness as the PW Stormbreaker. And, it would seem, even the conductor is similar. However, there is a difference. Cardas is a little warmer and more emotional. Stormbreaker is more V-shaped and wider.
High end (IEM) cable thread: impressions, pics, comparisons and reviews.
- Thread starter flinkenick
- Tags
- cable
Amadeo Nospherathu
In my impression, Cardas Clear Light does not have these problems. It is not darker, but it's just more organic in general and doesn't emphasize high frequencies, paying more attention to midrange.I have heard the EE odin and the stock cable, the Storm breaker is some how too aggressive in the upper frequency but lack of density and extension in the lower range.
Sound Eq
- Nov 9, 2013
greetings, can i ask if a silver cable shows oxidation, how would that affect the cable conductivity, as my silver cable is showing oxidation
Amadeo Nospherathu
Theoretically, the impact is bad. Because the oxide has a lower conductivity than pure metal. Practically - this is a very small part. So in practice it is hardly possible to hear the changes. In addition, silver cables often turn green. However, sometimes this is also the case for copper.greetings, can i ask if a silver cable shows oxidation, how would that affect the cable conductivity, as my silver cable is showing oxidation
Sound Eq
- Nov 9, 2013
hi any good palladium iem cables sold for 300 usd, or are all palladium cables extremely expensive
It is more expensive than Gold Plated cable, 300$ is hard to get a realhi any good palladium iem cables sold for 300 usd, or are all palladium cables extremely expensive
justsomesonyfan
- Sep 24, 2013
tianwaitian cable maybe? a bit over 300 thohi any good palladium iem cables sold for 300 usd, or are all palladium cables extremely expensive
justsomesonyfan
- Sep 24, 2013
Looking to buy a 4.4mm/mmcx Liquid Links Evua if anyone's selling
PhenixS1970
If someone is looking for a new in box PWAudio First Times, have a look at my classifieds listing .
findthereal4
Has anyone tried these pure silver cables?
TItan Ag - Labkable
Dream Duet
Silver Dragon - Moon Audio
Which one gives the best improvement in terms of clarity?
Which is the best for JH Layla?
Thanks
TItan Ag - Labkable
Dream Duet
Thanks
olddude
Silver Dragon is very clear. It needs a warm source and a warm IEM or it will be too clear and sharp.
findthereal4
Have you tried the dream duet and the Titan Ag?
Sound Eq
- Nov 9, 2013
you can buy from me adapter with bass boost, and use any after market cableHas anyone tried these pure silver cables?
TItan Ag - Labkable
Dream Duet
Thanks
https://www.head-fi.org/classifieds/whyears-jhaudio-iem-cable-adapters-with-bass-boost-dial.6311/
Amadeo Nospherathu
The first and second I did try.Has anyone tried these pure silver cables?
TItan Ag - Labkable
Dream Duet
I use Pure Silver by Moon Audio Silver Dragon v3.
And I used Labkable Samusai 3, Ag / Pt, it's good. However, it may be a little too soft at high frequencies. The sound is a bit analog.
Silver Dragon is a very good cable for its price. I made myself a "Double Dragon" - a double version of the cable. Moderately thick (I have thicker cables). Maybe the stock version can only be called a little rigid, but my version does not have this bad.
Little problem - this is not stock cable, you can't buy it from Moon Audio. So I buy 3 meter and made 1.5 m cable with double thickness.
In addition, pure silver usually gives an honest, smooth and transparent sound. Although in practice you need to see what kind of cable is meant. Some additive to silver (gold, platinum, palladium) usually shifts the sound to a slightly more analog and warm sound.
If you need something honest and transparent, I would choose Silver Dragon. This is exactly what I liked, for example, with my EE Wraith.Which one gives the best improvement in terms of clarity?
Updated:
I was wrong, Titan Ag and Crystal Cable Dream Duet are still pure silver. Both companies' love of experimenting with materials misled me.
findthereal4
The first and second I did try. And this is not pure silver.
Pure Silver Only Moon Audio Silver Dragon v3.
THank you for your reply on the cables above.
Isn't the Wraith already very high sounding? Pairing it with silver dragon not overkill?
Total: 6 (members: 0, guests: 6)
