PW audio First TimeS
Specs:
Jacket Material: soft PVC and Morandi dark blue nylon jacket
Conductor Material: Copper
Conductor Gauge: 26.5AWG
Number of Conductors: 4
•New flagship of flagship series.
•Base on Orpheus cable structure as the cable design.
•Use a new type of copper as a conductor which we studied for about 9 months for testing and recording a result.
•Sound natural with details, good dynamic with enchanting vocals and a big soundstage like an open headphone.
Sound synopsis:
Warm, fairly neutral but very slightly towards the dark side. Bass is on point and well portrayed, punch is there while it’s not too boomy or too bassy; I’d describe the sound of the bass on this cable to be just right. Make vocals are thick and smooth, while female vocals are never shouty or harsh. I’m my opinion it kind of tames the 3k peak of some ‘weeb tuning’ iems like the moondrop s8. Treble is again smooth but not diminished at any way, also diminishes potential harshness of treble. Hotel California’s guitar harmonic at around 3:00 was tamed but just enough to keep it natural. It maintains the sparkle or brilliant treble extension of the moondrop s8.
Technicals:
This is where in my opinion the cable shines. The instrumental separation is super strong that I could very easily pinpoint where the instruments are and which instruments play on which side, even on poorly mixed tracks. Soundstage is wide, depth and height is above average but not as exaggerated as the width
Cable build/ quality:
The knitting is fairly loose and the texture of the cable feels cheap. The splitter is made of metal, hence noticeably heavy and the chin slider is quite stiff. The flexibility is average, and if feels like it’s gonna deform if I bend the cable even very slightly. The plug is quite heavy than average also. One thing I liked about the design is that it specifies the cable’s serial number, and demo products would be labelled as ‘demo!’ On one side of the splitter. This could effectively prevent resellers selling used demo cables to customers. But still, I didn’t like the build quality too much.
Conclusion:
This cable really excels in terms of both tonality and technical performances, just unfortunately the build quality isin’t on par with the sonic performance (IMO). This cable is suitable to be paired with fairly neutral to bright iems to tame down the 3k peak and some sibilance. If you want flagship sounding cables, make this be in your shortlist.
Rating:
Sonic performance: 9.5/10 (vocals could be slightly more present, but I’m nitpicking here)
Cable build: 8/10 (made of high quality materials but I didn’t like the loose knitting and the relatively heavy splitter and plug)
Final grade: 9/10 (cable texture and quality is definitely bugging me)
