reading too much review can sometimes confuse more and more which to buy
which out of all these has
1- great great bass quality and quantity
2- warm
3- rich full layered sound
4- no harshness
i really can not wait longer for the denon to be released as then i am sure another one will come out and so on and by that i will not be able to make a secision to buy any
i listen alot to edm, synthpop. metal, progresisve rock
price is no issue
There is only ONE BT Headphone in the world in this moment which provide ALL what you listed.
The Audio Technica ATH-WS99BT.
The Fidelio M2BT provide only points 1-3 (and are not as warm as the ATH.
The UE9000, they have more rolled off highs than the Fidelio, so this solves somehow the problem of harshness, although it is better to have not harsh highs than rolled off highs, and the ATH are much more detailed than the UE, and have more quantity and quality of bass (but with no artificial boost).
By 2 or three, compare them, chose one, send the others back, and be happy.
There will ALWAYS be other ones coming.
When a really much much better one comes out, you can sell yours and buy that one.
But when talking of this level of headphones, it's not going to happen that the difference of quality can be so huge.
So, as long as you like the sound of one, you'll be fine with it.
The Denons, for what I understood, are not famous for being warm. But I clearly cannot know how that one will be.
The S1+ are a completely different animal than the original S1 and based on my preferences, the AF62 remains
one of the best BT can's I've owned but the S1+ are just as good if not better. Pendulumic listened to customer feedback and pretty much addressed all the gripes I had with the original:
- smallish ear pads that were a bit firm (replaced with larger ones and memory foam)
- slightly bass light and bloated mid-centric sound profile (they enhanced the bass (not over-bearing by any means) and tweaked the sound profile, the mids are still there but not overly emphasized)
For closed cans the sound stage is pretty good but isolation suffers a little. Ultimately, it's a small price to pay for the perfect (to me) sound signature.
They are not 100% closed. If you watch the back of the earpads you notice air vents... Which should not even be needed for the bass (it is by no means so powerfull). Probably they wanted to improve the sound with a semi open design.
I personally think they should have not removed so much upper mids and should have removed a bit more lower mids.
The bass is perfect for normal music. They are anyway on no means bassy cans. Not even EQed.
The pads could be a bit thicker. My ears touch the drivers.
The AF62 is completely different. Much brighter. Colder, somehow.
I did not like it. We have different tastes
And they have a really serious problem with the bass. When EQed, it immediately distorts very badly. Impossible to use them with any kind of bassy music.
