- Mar 20, 2013
thanks God no wholes
If there were any, you would have noticed by now
Stay updated on iFi audio at their sponsor profile on Head-Fi.
Just if anyIf there were any, you would have noticed by now
If you've got a nice DAC I recommend Kinki Studio Thr-1So I've got a Susvara on the way. Is there anything in my amp stable that will come close to driving them properly? I know the Crack won't be a good match, but I've had success driving my HE6SE v2 from the balanced output of my Liquid Platinum and the balanced output of my Magnius. And I have a Jot 2 on the way in like two months or so.
What of my amps will do the best for now, and how much am I leaving on the table with them?
I do have a Luxman R117 with a HFM speaker tap to XLR adapter I'll try but it's not terribly convenient given my setup.
Not realy tbh....Is there anything in my amp stable that will come close to driving them properly?
I mean the LP is the best bet for now, but I would very seriously recommend stepping up your amp game. Even just something like a V281 will at least get you part way there as a headphone amp, but if you need something under that price wise I would pretty well be at a loss if I am honestWhat of my amps will do the best for now, and how much am I leaving on the table with them?
This would certainly be worth a try. The good news is that its hard to get sus to sound bad but its also fairly hard to get sus to actually sound its price IMOI do have a Luxman R117 with a HFM speaker tap to XLR adapter I'll try but it's not terribly convenient given my setup.
As eskamo said it's going to be tough. I think under 1k the best amp I heard was a Ragnarok v1. Resolution isn't quite where I would like it but does power low end from memory.So I've got a Susvara on the way. Is there anything in my amp stable that will come close to driving them properly? I know the Crack won't be a good match, but I've had success driving my HE6SE v2 from the balanced output of my Liquid Platinum and the balanced output of my Magnius. And I have a Jot 2 on the way in like two months or so.
I would throw the IHA-6 in that category. Might not be as powerful as the Rag, but enough to get the job done.As eskamo said it's going to be tough. I think under 1k the best amp I heard was a Ragnarok v1. Resolution isn't quite where I would like it but does power low end from memory.
I think there’s been plenty. Just search “vintage” in this thread for loads of past input.Has anyone experinced these with vintage receivers or amplifiers?
Not many DACs can do 10v nice! My M2 Tech Young Mkiv can as well, it makes my Taurus Mkii sing with Susvara lol. I only use 5v with thr-1 since it's a beast already. The Taurus Max is 12v.I tried susvara out of CYRUS I9-XR amp, I felt the sound was off, the magic tonality of sus was gone.
https://www.cyrusaudio.com/products/i9-xr/
then tried it with my avid hifi - integra, with the same conclusion
https://www.avidhifi.com/amplifiers/integra-integrated-amplifier
till now I prefer violectric 590 over these mentioned amps and also over the tube amp auris headonia, using ifi pro dsd as a dac with 10 v output, and tara lab power cords. Using the violectirc with its internal dac is not to my liking, so I need the ifi pro dsd with it set at 10v
next I will test sus out of accuphase e480, as from what I heard so far from using speaker amps was far from my tonal preferences
When mine arrives I'll play with it through my Luxman R-117. See how it goes with the headphone output, the headphone output of my TP-117 preamp, and speaker taps with the HiFiMAN speaker-to-XLR adapter. See how 160 WPC into 8Ω plays with these.Has anyone experinced these with vintage receivers or amplifiers?
