lumdicks
- Oct 1, 2013
I strongly recommend Kinki Studio THR-1. You can look at the review of SoundNews below.I see thanks. Actually the Ferrum Oor is not that much more and is getting good reviews. Do you think that would be a better choice for a medium size/medium budget Susvara amp?
https://soundnews.net/amplifiers/headphone-amps/kinki-studio-vision-thr-1-review-a-gentle-giant/
I have also shared a review on the THR-1 thread and extracted as follows:
My THR-1 has burnt in for 1 week now and I am keeping it on 24x7. I just want to share that it is the biggest hidden gem in my over 20 years voyage in Home HiFi, portable audio and desktop head-fi. I shall try to summarize my experience below.
1. THR-1 really needs at least one full week or 300 hours at best to burn in (thanks @joseG86 ). I strongly recommend to keep it always on as it only generates a bit warmth in the case.
2. It is powerful enough to drive all low sensitive CANs including Susvara. I usually listen at a volume level at position at 12 or 1 o'clock for my Susvara.
3. THR-1 strikes a perfect balance between tonality, resolution, musicality and output power. It performs perfectly along all frequencies with deep and textured bass, sweet mid and smooth but well extended high. The sound is so smooth, cohesive and musical that makes every minute of listening so enjoyable.
4. The sound is neutral with a bit on warm side. Sound signature is more on tube with speed and dynamics of solid state.
5. Compared to Burson Conductor 3XR, the output power is similar. The Burson seems more resolving which throwing crazy details in your face. For THR-1, all details are also there but in a more subtle and harmonic way, connecting notes into music seamlessly.
6. Only weakness compared to my Benchmark HPA4 is a bit lower resolution and higher noise floor, in which HPA4 is at reference level. I am now using my HPA4 as Line Amp and THR-1 (at maximum volume) as power amp, and it improves the above weaknesses vastly.
7. I have never really enjoyed my Stellia previously as I found it a bit harsh and bright sometimes. With THR-1 the Stellia just sounds perfectly without any harshness and brightness in the mid and high.
8. The THR-1 is the worthiest purchase of mine ever, and at the price I paid (a bit higher than USD1K) it is a real steal.
9. Since it was fully burnt in, it is my favourite amp at all time (please see my signature for desktop amp I own).
10. THR-1 carries my highest recommendation and if audition is not possible, you won't go wrong by getting it blindly.
