HiFiMan Susvara
Aug 28, 2020 at 7:24 PM Post #4,501 of 25,878
I hope my susvara has the 3.5mm connectors. My dealer said it arrived at the store at the beginning of August and he did not open the box to verify. I decided to buy the asgard 3 to drive the susvara until I do more research on totl amps. For only $200 and based on the specs I think it should be good enough for now.
I ordered mine yesterday how long it took to reach your dealer ?
Aug 28, 2020 at 7:27 PM Post #4,502 of 25,878
I beat around the bush for a while, but I should have pulled the trigger sooner. WA33 sounds great, even on stock tubes for now. :)
you didnt get the Bakoon 13R ?
Aug 28, 2020 at 7:36 PM Post #4,503 of 25,878
I ordered mine today and it's arriving tomorrow. The dealer said that the date printed on the box is August 14th so I have my fingers crossed that it's the 3.5mm revision.
Aug 28, 2020 at 7:59 PM Post #4,504 of 25,878
i think it will be 3.5mm ,, since the beginning of 2020 i heard the they changed it to the 3.5
Enjoy :)
Aug 28, 2020 at 8:15 PM Post #4,505 of 25,878
Enjoy :)
Thanks! My asgard 3 arrives next week so I will be powering the susvara with an el amp 2. I'll report how badly it sounds throughout the experience.
Aug 28, 2020 at 8:43 PM Post #4,506 of 25,878
I have the woo audio 22 and gsx mini. Both can run my TC Phi with thunderous bass. Volume pot is around 10 to 11 o'clock so lots of headroom..
With the Sus, I can get to about 12 o'clock but then the mids and highs get way too loud.
I'll run them in for longer and will also try it with my Benchmark hpa4 later on.
Might be your source...while I very much enjoyed the DAC-3 when I owned it, it hit hard and fast...but a tad too fast (and a tad thin). On my DAVE with the GS-X mini or HPA4, I am with Jose on this one and just love the bass presence and impact.
Aug 28, 2020 at 8:56 PM Post #4,507 of 25,878
I have recently paired the susvara with the bakoon 13r which is the best pairing I have yet heard....the only thing that dig as deep was one of the super expensive wells amps I heard at canjam..otherwise thus far the 13r has been the best pairing I have heard
Aug 28, 2020 at 9:02 PM Post #4,508 of 25,878
Trying out speaker taps for the first time, using ahb2 and gsx mini as the pre.
Do I need to flick any of the switches on the back of the AHB2? The gain switch (?) on the AHB2 is all the way to the bottom. Options at 8.2, 14.2 and 22 dBu.
Aug 28, 2020 at 10:45 PM Post #4,510 of 25,878
That's another great picture from you! Which wa33 version did u get? I'm thinking of the JPS Labs edition that comes with the upgraded tubes (seems more "value" for money if ordered from Abyss, as Woo doesn't include the tube upgrade if ordered from them..). After u got the wa33, does the hpa4 still get any play time?
It's the standard, the JPS version does seem like a solid deal since it includes the tube upgrades. I do still use HPA4 to A/B for fun, but mainly listening to WA33 now.
I did, it's an amazing SS amp but I wanted to try some tubes. :)
Aug 28, 2020 at 11:23 PM Post #4,511 of 25,878
Not true as mine was drop shipped a few months ago and I did not get the 3.5mm :)
yeah i guess you are correct , with covid19 time is weird , it felt it past long time ago , GoldenOne reported that he got his 3.5mm pair in Jul 13 and i read it somewhere else maybe prioer to that by 2 months, so best guess that they started the conversion in May
Aug 29, 2020 at 1:43 AM Post #4,512 of 25,878
Ok so I've just spent the past few hours with the susvara. Using the wa22 and gsx mini as pre amps and ahb2 + speaker taps.
Am I missing something? Because I seem to prefer the sound from the headphone out directly, over the power amp speaker taps option.
Direct from the wa22/mini, sounds like I'm getting similar dynamics, but with an overall weightier, thicker and warmer sound which is quite nice, as opposed to a bit leaner but more distinct/cleaner sound from the AHB2.
Or is it just the sound from the AHB2? Maybe try other speaker amps? Or is this a lesson in futility and I should just get a wa33 and call it a day....?
Aug 29, 2020 at 2:23 AM Post #4,513 of 25,878
Thar sounds like its the sound signature of the AHB2 more than anything else, but I could be wrong..
Some people are really happy with the Susvara from HP amps, I've had the best results for me personally from speaker amps. Just FWIW.
Aug 29, 2020 at 3:26 AM Post #4,514 of 25,878
Use your hpa4 as preamp with ahb2. It is the ideal pairing with ahb2. (Use Mid gain setting on ahb2)
Recently, I had tried @ajaipuriyar 's susvara with dcs Rossini + clock & headtrip reference & there was no lack in bass body, extension, resolution, speed. The note density/weight & texturing was at another level.
Aug 29, 2020 at 6:23 AM Post #4,515 of 25,878
@jlbrach i see in some previous posts that you have previously owned the moon 430ha(d).
how did you find the amp generally and specifically with the susvaras, if you had them together?
tia
