Get the Topping E30/L30 stack. They form a wonderful rack together with the Sundara.Hi guys,
Thinking of buying Sundara. So what would be the good amp for them? I'm in europe so Schiit is not available. I need to choose between Topping, S.M.S.L.?
Thanks!
Hifiman Sundara (HE400i upgraded, around $500)
- Thread starter mtoc
limaaa
- Dec 23, 2014
They are powerfull enough for Sundara?Get the Topping E30/L30 stack. They form a wonderful rack together with the Sundara.
There's more than enough power.They are powerfull enough for Sundara?
I think both of those choices may be a little on the sterile side for the Sundara. I really enjoy my Sundara on the Little Dot 1+ with updated tubes. The tubes add a nice bit of warmth that matches the neutral presentation of the Sundara perfectly to my ears. I know you said Schiit is out, but I also love the Sundaras on the Schiit Lyra. I good tube hybrid amp or warmer solid state is a good match for the Sundaras.Hi guys,
Thanks!
Also Chord Mojo if you need portability.
yassdaboss
- Sep 2, 2016
In my opinion Schitt Asgard 3 is perfect .
NoMongoose
I have big ears that press against the inside of the ear cup with the stock pads, which gets extremely uncomfortable after a while. I replaced them with Brainwavz XL earpads (30mm depth) which are perfect from a comfort perspective, but they basically ruined the sound as you said. The Dekoni pads (23mm) are even more shallow than the stock pads (25mm) so I don't think I can use them. Do you have any pad recommendations that are comfortable for people with big ears but don't completely ruin the sound?When it comes to the Sundara the ultimate answer is "don't even try", lol
Seriously, swapped pads in all my previous headphones with interesting / good results every time. With the Sundara in the other hand it is always pure garbage, that is my experience and it matches what i see others reporting as well.
The stock pads are the perfect pads, the only real upgrade i think are the Dekini pads, these will not change your sound signature but will improve comfort and durability.
https://dekoniaudio.com/product/dekoni-audio-elite-hybrid-earpads-for-select-hifiman-headphones/
I personally don't think it is worth the investment though.
You are not listening, the answer is a hard no.I have big ears that press against the inside of the ear cup with the stock pads, which gets extremely uncomfortable after a while. I replaced them with Brainwavz XL earpads (30mm depth) which are perfect from a comfort perspective, but they basically ruined the sound as you said. The Dekoni pads (23mm) are even more shallow than the stock pads (25mm) so I don't think I can use them. Do you have any pad recommendations that are comfortable for people with big ears but don't completely ruin the sound?
If you like the Sundara's sound signature, but want a bigger pad/ear cup, you may want to try the Ananda. I've read they have a similar but more refined sound of the Sundara while having the larger ear shaped cup and pads. They are on my short list of next cans to try.I have big ears that press against the inside of the ear cup with the stock pads, which gets extremely uncomfortable after a while. I replaced them with Brainwavz XL earpads (30mm depth) which are perfect from a comfort perspective, but they basically ruined the sound as you said. The Dekoni pads (23mm) are even more shallow than the stock pads (25mm) so I don't think I can use them. Do you have any pad recommendations that are comfortable for people with big ears but don't completely ruin the sound?
Kammerat Rebekka
^With the most recent pad revision it’s the other way around. The Sundara is the most refined sounding of the family (Sundara, Ananda and Arya). If you want something brighter with more ‘sparkle’ up top, then the Ananda is a safe bet. If you want something even brighter yet, the Arya comes in handy
NoMongoose
I got the Dekoni pads and it turns out they are a big improvement in comfort over the stock pads. Although they are the same thickness the memory foam is firmer so it doesn't get squashed down as much.You are not listening, the answer is a hard no.
not sure why you quoted me as a told you so I doubt others will agree that pads made for the entire HE series won't completely affect the Sundara sound but I also doubt most people will spend $60 on replacement pads to find out, quote them and ask them to find out or I assume it has changed the sound since that is what we were talking about.I got the Dekoni pads and it turns out they are a big improvement in comfort over the stock pads. Although they are the same thickness the memory foam is firmer so it doesn't get squashed down as much.
my bad the hybrids are $70 not $60 which is 25.9% of the lowest total cost @ $270 open box with coupon code I have seen them for that money I sure hope it makes the sound somehow better or keeps it exactly the same interested to hear how it sounds for that muchnot sure why you quoted me as a told you so I doubt others will agree that pads made for the entire HE series won't completely affect the Sundara sound but I also doubt most people will spend $60 on replacement pads to find out, quote them and ask them to find out or I assume it has changed the sound since that is what we were talking about.
NoMongoose
For me it was a £140 DAC + £140 amp + £300 headphones. Dekoni pads were £60 so they were 9.37% of the overall cost, it made sense for me as comfort is important. Sound is similar to the stock pads as expected.my bad the hybrids are $70 not $60 which is 25.9% of the lowest total cost @ $270 open box with coupon code I have seen them for that money I sure hope it makes the sound somehow better or keeps it exactly the same interested to hear how it sounds for that much
I'm glad that you think that but since you never gave any description of the actual pads or sound I guess we will never know. I have however tried Focuspad-A which are also hybrids, made by Hifiman for the 560 that look exactly the same as the Sundara's and they changed the sound drastically so I remain skeptical until I hear from another party, feel free to actually post which pads you bought though.For me it was a £140 DAC + £140 amp + £300 headphones. Dekoni pads were £60 so they were 9.37% of the overall cost, it made sense for me as comfort is important. Sound is similar to the stock pads as expected.
Total: 11 (members: 0, guests: 11)
