Hey guys,
Just ordered the he6se v2 from Adorama for $600 including 2 day shipping. Went off a rec from BGGAR who I seem to have similar taste to. Can someone please link where I can get the honeycomb grills, and what (vegan) pads I should pair with them? I ordered an Ibasso dx300 to drive them and am pretty excited by the combo. Currently have a Sundara running on an M11.
Thanks!
Hi
@JoshG1217
First, congratulations on your decision! I love mine.
Second, in answer to your question - these are the grilles I bought
https://www.ebay.com/itm/265277136476
And lastly, I'm just a little concerned that you won't get the most out of the He6se v2, because your dx300 says it's only rated for 1240mW@32ohm, 168mW@300ohm. I'm not knocking your DAP. I still have my old Ibasso dx90, and I use it when my OPUS #1S is packed for business trips. It's still going strong! They are great DAPs, but these headphones aren't really intended for "portable class" devices...
I think the minimum for these to even start performing "properly" is 2 watts into 50ohm. I don't want you to think that the headphones are "over-hyped" because you're not hearing what the rest of us are.
To give you an idea: My Artemis desktop amp outputs 50Ω, 3.28W RMS, 300Ω, 800mW RMS (And while it drove them "NICELY" in terms of characteristics, the volume was too low. On the other hand, my Topping A90 and SMSL SP200 were able to power the He6se v2 loudly enough, but just didn't really sound that great.
First fix: Bought a Burson Soloist 3XP, and THEN I was happy with how they sounded.
2nd fix: Found an old Harmon Kardon HK 870, then hooked it up with my He6se v2 running off the speaker taps. NOW I'm extremely happy with them. MUCH cheaper than spending "mega-bucks" on the truly heavy-duty amps that are available out there. (With compromises, of course. It's "vintage", not a balanced amp unit, etc.. But I spent less than $300 for what I consider EPIC sound quality instead of high thousands or double-digits thousands.) I love them but I'm not ready to plunk-down for options out easily over $15K for $600 headphones... (Looking at YOU Woo Audio WA33 JPS Elite, you tempting, VEXXING thing, you...)
Oh, to be clear, there ARE less exotic amps out there that you can buy that are reported to sound GREAT with these headphones.
Schiit Audio Jotunheim 2 (https://www.schiit.com/about/news/i...mQ3pE6GIj54TLx9YpNmzkE98NiN9RmUxoCAIEQAvD_BwE) $399USD & up
and
Flux Labs FA-10 ( https://fluxlab-acoustics.com/product/fa10/ ) $749USD & up are 2 options that I've seen good things about when it comes to properly powering the various He6 versions of headphones. Both are reportedly solid sub-$1,000USD options. My Burson Soloist 3X Performance is juuust over the $1K mark at $1,144, and I can tell you personally that I love it!
Burson Soloist 3XP (https://www.headphones.com/products..._content=sag_organic&utm_campaign=sag_organic)
So just wanted to prep you in case they don't sound as great as you were hoping. These headphones scale incredibly with power. (Even more-so than my Sennheiser HD650, and they scaled better than anything I had heard before I got these HiFiman He6se v2s. (Yes, I have HiFiMan Sundaras too, and they sound great from the get-go, but don't really scale that well. They pretty-much try to give you their best no matter what.)
By the way, the headphone to speaker tap cable I bought was just this:
https://lqicables.com/collections/a...-pin-female-to-speaker-taps-banana-plugs-pins
It works for me. People make them, order pre-mades like mine linked above, or have them custom-built by makers like Hart Audio, Periapt, Forza Audio Works, etc...
I know I dumped a lot on you, but I wanted you to have all the info I wish I had known going into this. (From MY perspective, of course. Others may feel differently or have better advice.) I just wanted to provide you with a starting point.
Good luck and looking forward to hearing your impressions/experiences!
