Initially I was going for an R2R DAC (Holo Cyan mk2) but after testing the Lampizator big7 (no EQing required for all genre), I prefer the Lampi even though it is a sigma/delta.
Currently using PC as my source thru ifi zen dac, so I use an EQ software to slightly tame the high ends.
Budget up to $1,5k. I listen to many kinds of music, so I prefer a balanced setup. Better not too smooth. I got an AK4499EX DAC. Those are probably smoother than ESS?
That is an audiophile myth. A DAC chip would have to have deliberate DSP processing built in to attenuate or accentuate a frequency or group of frequency. Until somebody can demonstrate in properly constructed, valid blind listening trials that they can consistently identify a difference, the idea that AKM and ESS chips are different in this key respect is simply rampant speculation fueled by bias creation and expectation confirmation. I have owned several examples of both companies chips over the years and personally never noticed this effect.
There is a well documented ESS hump that many companies have learned how to eliminate or significantly reduce, and I am not even sure if the hump was ever audible as opposed to measurable.
Yes it’s not yet shipping. There’s a dealer here in Hong Kong, who’s got a demo unit. Can test it then pay a deposit to get priority once stocks arrive, he said ETA around mid/late January. I was like 99.9% going for Cyan2 but that night at my friend’s place, his Lampi B7 changed my mind. And those tubes just add much more points.
I would purchase the he1000 V2 straight from the website, its $1209 out the door, thats where I have purchased all my hifiman he1000 series. I purchased refurbished, always amazing condition, and it's back by the standard hifiman full warranty. Shipped fast and got to me quickly. Also you earn reward points now when purchased from the website. Earn 10% back in member rewards. $1 is 1 point.
That is the safe way, and recommended. OTOH, those short of cash, HFM for the most part drop in price over time substantially. Part of that is that warranties do not convey, and HFM releases new varieties and versions like mushrooms pop up in a damp dark woods.
With the SE dropping to $2k and the newer and hot Stealth at $1.4k, the used market on v2's has to be drifting towards or under $900. The HEX v1 and v2 prices dropped a lot when the XS came out, the HE-6 SE v1 and v2 both got the Adorama price guilotine.
However, no warranty, and if you didn't buy from a trusted user (plus they first came out in 2017?) - well that's the risk/joy of the used market.
65 Hz +2.4 db Q 1.0 hopefully using a bass shelf, if not then set it to 35 Hz Q 3.0
4k cut 1.8 db Q 1.8
7.5k cut 2.8 db Q 2.0
6.2k cut 3 db Q 8.0
13k cut 3.6 db Q 3.5
probably need to add a bit to the pre-amp setting since its mostly negative cuts.
I used to love the v2, but the Stealth IMO is better and has better bass impact (under 100 Hz) than the v2 - but the highs do need to be tamped down - like what was suggested.
Recommend using your favorite 10 cuts of diff music types and adjust if its not the correct timbre.
Anyone of you using the HE1000 Stealth with a Ferrum Oor / Hypsos combo. I would like to know if this is a good combination (synergy).
Adding a Ferrum Wandla to this combo would be my personal endgame....
The actual chip ( ess or akm ) is just a small piece of the overall presentation.
Other important factors are the quality of components such as resistors and power supply and etc.
My gustard x26pro has an ess chip but it is the most analog sounding ess chip I have heard.
DACs definitely make a significant different if your headphones / speakers are transparent / resolving enough. I think all he1000 versions or better will be able to hear the difference in sound signature.
I am just sharing my experience......
For example, cables and interconnects and power cables didn't make any difference using the hd6xx.
Using the he1000se, any change in my audiochain made an audible difference. Amp and DAC being the biggest difference compare to cables and interconnects.
