This is mainly to compare the difference of HE-1000 V1 and V2, as I promised HIFIMAN when
I was informed I got chose to receive V2 free upgrade.
thanks, that is really informative. and very similar to my impressions on the V2......
Thanks for the listening impressions of the V2 vs the V1.
I'm curious as to why some members are finding differences in sound performance between the V2 and V1....and others, ...not so much?
Any thoughts as to why or what may be the reasons for this?
Thanks.
Maybe this is because the differences between V1 and V2 are very specific and really very limited to certain parameters. if you are not interested / not sensitive to that specificity, you don't care.... for example, I don't find my V1 to be harsh (at all) in the treble, so if the V2 is "correcting" this harshness I will not be able to ear the difference.
Or maybe this is because many of us have already "modded" in some way the V1. for example, I did find the stock V1 to be a little "thin" in the mid-bass and bass, and that's why I bought a different cable, and with that the V1 sounds perfect to my ears...
The v2s are more comfortable than the v1s due to the lighter frame. However if you dont move your head alot I find the v1 earpads more comfortable. The v2 earpads are more firm and dont collapse as much as the v1 which definitely gives the sense of greater pressure on your ears. You can literally fall asleep with the v1 earpads on but the v2s will definitely create enough pressure on your jawline so that you are always aware that they are on.
OK, the next question will be, how do they compare after the V2 has burned in for a while.
Thanks for the fine write up!
Mine changed significantly after 20 hours or so. The bass got deeper and more prominent. I was suspecting that Hifiman strings that nano thick membrane tight during manufacturing, and it takes some time to loosen up to make large bass waves. This is just my theory.
