LifeAspect
Just noticed a scratch on the iron with my brand new unit which I didn't notice during unboxing... Otherwise sounding fine and no complaints atm.
Pros:
very neutral timbre, maybe a little bit on the dark side (not euphonic), absolutely not bright at least to my hears (HE6 and 507 are way brighter)
bass (extension, texture, impact), the best I've heard (admittedly, never heard an Abyss)
mids (resolution, fludity), one of the best I've heard (only 009 IMHO is slightly better)
higs (absence of grain, good timbre), one of the best I've heard (again, IMHO 009 is slightly better)
very easy listening, can listen literally for hours with the HE1000 without any fatigue
very realistic impact without any bloominess, one of the best I've heard (and, yes, IMHO the impact on LCD3 is too bloomy for my taste)
incredibly transparent, at 009 level IMHO
very realistic soundstage (HD800 has a wider soundstage, but IMHO is a little bit unrealistic)
Cons:
not so airy, IMHO HE6 and 507 are more open and airy than HE1000
the headband of the production cans is way too short
all the above is just IMHO and of course YMMV
Out of all the negatives I have seen the only one that concerns me is the “odd imaging” and “kind of distant sounding” comments.
I am very sensitive to that particular problem. I do not like the SR-009 because even though technically it is maybe the best headphone ever- to my ears the spacial imaging is out of whack and that was a breaker for me.. It is not noticeable at first- but my ears caught on after a few weeks. The HD800 imaging seems fine to me but in that case I feel the sound is distant- and I do not like it. Generally I like moderate soundstage in a headphone--- just enough to take it out of the head- but not so so big- that the spacial presentation starts to sound false.
Does anyone else hear this “out of whack imaging” issue and is anyone else bothered by this particular issue?
The imaging oddness / "frontal diffusedness" can be remedied to an extent with an earpad-angling mod (somewhat analogous to one of the steps I did with HE560 modding).
Interesting. So far I don't even know how to remove the earpads. However, I don't even hear any «frontal diffusedness». I take it you're speaking of the HE1000, not the SR-009.
If you compare HE1000 against Audezes and whatnot, the relative diffusion of frontal (depth) imaging is quite apparent.
Earpads are clipped in via little tabs that go under the baffle ring, if you've owned previous Hifiman cans and taken those earpads off, same principle.
Anyway I won't go into detail on HE1000 modding until after my review of the stock cans is out.
