Armaegis
Modern Modder Man of Manitoba
HTML... uphill, both ways!
- Oct 18, 2009
Why would it not work?
Signal is signal?
Let's say you have a hydroelectric dam. You know precisely the difference in water depth on each side, and this generates your electricity. This is your balanced (XLR) line. It doesn't matter what the absolute depths are on each side (you don't actually know, you can't see underwater), only the difference.
Now let's take remove one side (the lower side for this analogy to work). Now you're just going to vent water into... an empty basin? You don't know, because you only knew when there was water. If you're lucky, that gound is exactly where the water line was before (so it was a puddle). But it could be lower... much lower. This is pretty much what is happening when you use an XLR to RCA converter. You are referencing one side of the dam not to the other, but to an unknown location of ground. Maybe you'll get lucky.
So in summary, play it safe and use a transformer to convert to rca if you need to.
