ohhgourami
- Apr 16, 2010
Older pairs have 4 screws. Newer ones have 6. Not sure when the switch was made.
My Audeze vegan pads arrived today - they shipped it to me in Japan fast. I taped one to the ring; the other I fit on the ring like the hfm pads. I like the way the taped pad rotates freely. After my aluminum rings come from hfm, I`ll figure out how to apply the pads more permanently. Nice of audeze to include 4 rings of double-sided tape.
So I finally have what I consider to be all the ingredients in place for my modded HE-6 project. Naturally I decided to have a long listening session, and do some comparisons with my beloved HD800.
The HD800 loves the Andix tube amp. I had several variations for A-Bing: The HE-6 is running via its XLR4 plug to the Andix`s speaker taps; the HD800 is running from the Andix`s low-impedence single-ended headphone output. So I can A-B just by lowering volume and turning a switch.
For source, I was using my AK120ii with twin SirrusLogic dacs, from its single-ended output to the Andix. Alternately, the AK transports to the Andix via optical cable. The guy here who built the Andix put some 24/192 dac in it and swore it`s `super-musical` but I don`t know exaclty what it is . . .
So there I was, all set up, listening to a wide range of my faves, when I was floored by two realizations:
1. I am ridiculously lucky to have these two phones here !
2. I think I may actually sell the HD800.
That second realization really was a shocker. I never thought it would cross my mind to sell the HD800. The difference between the HE-6 and HD800 is fascinating for me: my modded HE-6 seems to have EVERYTHING the HD800 does, with that extra bass weight. . . I really love the complex sound coming out of my HE-6. The HD800, with some stuff, sounded like detail for details sake; the HE-6 always seemed liket it was outputting MUSIC . . .
I know you all have been here, or somewhere very similar, before.
What mods have you done other than the Audeze pads?
Open-grilling and fuzzor. Also a lot of headband manipulation to make them fit well. (The HD800 still kills it in that department, of course)
Have you considered Lohb's headband mod? Truly a great improvement.
If you're a one can listener, it would come down to how they feel after long listening sessions. I use my headrest to support the cans once in position. I'm not a big mover once anchored (couch lock) as most of my headphone listening time is in the evenings. I've heard those 800s with plenty of amps and they are worthy of one can ownership. Once you start refining the rig to match your listening preferences, it's hard to keep it multi-functional for the best sound with all headphones. And we know how we do it, no compromise with the "A" rig. I also came to the conclusion the HE-6s are my preferred sound.
Those audeze pads looks like it might make the sound dark.
Where do you guys get your black Vegan pads? I got the Audeze vegan pads and they are brown.
ooops, did you order the brown one intentionally ? I personally liked the black vegan pads. When you order you can specify the black color.
Maybe you can return it for black one.
