Hmmm, which of the quotes is correct? Does the Magni have enough juice for the 400i or is it lacking and as a result sounds lean? Magni measurements (can't link due to head-fi link restrictions) show that it's almost flat to 10hz, so if it sounds lean with 400i, then it's not performing as it should and so is lacking? Would more juice help then?
The issue is that I have an Aune T1 and a Magni, and I'm under the impression that the T1 isn't driving the 400i as well as the Magni, but I don't know how much of an improvement I'd get with the Topping A30 vs Aune or Schit... Would extra power help or does the Magni already drive the 400i to its potential? Does the 400i benefit from Magni 2 Uber vs a normal Magni?
The A30 specs are very similar to Magni 2 Uber, at less than 60% of the price for me! So if it the Aune T1 dac to Topping A30 was an improvement vs Schiit modi+magni, that could be something interesting. And I could even go Modi + A30 and T1 + Magni, in case the A30 did better than the Magni but the Modi did better than the T1...
Sigh... So I'm 50/50... From search results in that thread, majority seem to think the T1 isn't the greatest with the 400i, imho, it works and sounds 'good', but does not drive the 400i to its full potential. In the short term, think I'll repatriate the Schiit stack, as for A30... I'm starting to lean away from it, but... Upgraditis dictates is could be an upgrade!
The Magni is a good amp, just not a great pairing with the HE400i, the Aune T1 is also good amp also, just does not have the current the HE400i likes but is quite good with HD650 and K7XX. Best combo DAC/amp that is reasonably priced is a Teac UD-301. It pairs very well with the HE400i to me and you can use the DAC output at the same time you are using the amp.
The thing to remember is you also need to consider how loud you want to listen at, for me its a very safe 68-75dB with peaks in the lower 80's dB. If you are listening at much higher volumes then the choice amp becomes more important. I would suggest saving until you can get to the $500 range for DAC and amp since I feel this is the sweet spot in price to performance, at this price you can get a Modi MB and Project Polairs, a really go pair that can drive almost everything. Or you can go one piece at a time and DACs and amps in the $500 range are quite good.
