NaiveSound
- Nov 8, 2015
I wonder what headphones I should move up to from 400i, I feel it's lacking some clarity I need
Why wouldn't a simple EQ adjustment for the peaks you didn't like be a better solution than pads which globally changes many things at once?
Would. You explain main differences, are they even above se846?
HE-560 is worth looking at too, if you don't have $3800 for the SR-009, not to mention an electrostat amp too.
I've only listened to the Shure briefly and I've never been great at comparing IEMs, I think over-ear headphones are far superior. I can't really weigh in there.
But the 560, in the clarity and imaging department just blows away the 400i in my opinion. Some still prefer the 400i overall though so not a unanimous recommendation.
What's your budget?
I'm a guy who prefers the 400i over the 560, but I certainly wouldn't argue that the 400i wins out on clarity/transparency. I don't think anybody would disagree that the 560 is more transparent than the 400i.
Strangely, I recently the chance to audition the 400i and 560 side by side...and while the 400i lost squarely in clarity...it simply sounded far more musical. The bass had more body and to a certain extent, slam, and it sounded rather nice indeed!
In my experience, quick side-by-side comparisons tend to lend you to pick the signature you're most familiar with. When I first moved from the 400i to the 560, I missed the more prominent mids of the 400i. After two weeks of listening just to the 560 and then switching to the 400i, I couldn't even finish a song as it just sounded so congested in comparison. With brief impressions, I tend to gravitate towards the signature I'm used to so its hard to really make an informed comparison without exclusive, extended time with everything I'm comparing.
I will say that I think the bass on the 560 extends lower and is more detailed and responsive compared to the 400i, the hotter treble response might mask that a bit but I've seen measurements that back that up as well, the 560 has a stronger bass presence.
I had a 560 for a week. I liked it a lot when sitting in my chair, with the right amp, and the right EQ setting. However, I rarely get to listen that way.
