Vartan
- Mar 25, 2014
Deckard
Matrix HPA-3U (M stage)
Lehmann Audio
Lehmann Audio
I saw that before. Is the deckard a poor value based on being a modified matrix?
I just had a thought pop in my head...
With proper amplification feeding the 400i, is it accurate to compare it to the light airy openness of the HD800S with a little less resolving power? I've listened to both the HD800S and LCD-2 in the weeks prior, and after listening to the 400i I feel like its sits between these two headphones in terms of tonality and resolving power.
I would have to say no, only because when I heard the HE-400i driven by TOTL amps like Liquid Gold, EC Balancing Act, Liquid Glass, MHA-100 and a few others it didn't scale much, if any over what I get from my Lyr2 with good tubes while the HD-800/800S were so much better than the HE-400i on those amps. The differences are also somewhat dependent on the genre of music you listen to, if you listen to jazz and classical the HE-400i can't compete with the HD-800/S, if you listen to rock, pop, country, and older music that may not be mastered as well then the differences become less noticeable. To me the different headphones is like getting the right tool for the job (genre).
So I've seen Schiit being thrown around a lot in here (sorry had to ). Is the brand good? Would you recommend the lyr2 for the 400i? I'd like to stay around $500 for an amp. I'll probably run the AK100ii into the amp for now.
Oh man, now I'm considering a Lyr2 and Bifrost Multibit combo. Would that pair well with the 400i, and offer a good platform for additional headphones down the road?
I apologize for the multi posts. I've been researching all weekend (at the expense of studying for school) and I just want to make up my mind already!
Is there a difference between the "pre-production" Focus-A and what's currently available?
I have one set of the current Focus-A pads, a bit more comfortable if your ears touch the edges. As for sound, it does smooth out the highs a touch but not in a good way to me, the highs of the HE-400i are not as extended compared to the HE-560 so the highs get a little too smoothed out for me.
What other headphones do you have? If only for the HE-400i then the Lyr2 will work quite well but I like the flexibility of the Ember more, the tubes it uses are cheaper and you only need one unless you start going for some really exotic dual tubes with adapters.
If you are willing to spend some $$$ on tubes then the Lyr2 will be better than the Ember in the long run but some of the really good tubes for the Lyr2 are $200+/pair, most of the good ones range from $25 to $100.
As @520RanchBro noted the Bifrost MB is not worth it, I have one and the old Uber is not far behind, I think the 4490 is a better DAC and cheaper.
I only have se846 IEMs and the 400i. I have a feeling I will pick up LCD-2/X and/or HD800S in the future. The Lyr 2 seems to fit the bill for all of the current and future headphones.
Just so I'm clear, you're saying get the Bifrost, but don't spend the extra money for the multibit. Please help me understand. Is the 4490 just the standard bifrost?
I picked up a lyr 2 and bifrost MB. what tubes do you recommend for the lyr 2?
