Four quick questions for you HE-400i owners out there:
1. How does the bass compare to the HE-400s and other basshead cans like, but not limited to the M100s/DT770s/etc.?
2. I hear the soundstage is its weakness...is that true, and if anyone has tried or owns the DT990s can you compare the soundstage of both of them?
3. Another one for the DT990 owners or those that have tried them. Do they sound airy at all like the DT990s?
4. I also hear these aren't difficult to drive, can something portable and relatively weak like the E11K handle them with good volume?
I am assuming you want as many opinions as possible so here goes my input, albeit limited so keep that in mind.
I have heard only the M100s and currently own the XS. While I should say that comparing closed vs open is a tricky thing, the 400i's are not the same in terms of level but the bass is better. The analogy I can think of is that the bass seldom 'lingers' like the V Modas. It is very quick to come and go. For eg, I listen to Jamie xx who uses a ton of powerful bass lines and his music sounds more coherent on the HE-400i's.
I used to own the DT880s and feel they were better wrt soundstage. Having said that, I tried the soundstage check from Audiocheck.net and literally got fooled thinking the pizza delivery guy was here! I think it may be source dependent.
FWIW, I have frequently read opinions of DACs/amps, esp on the cheaper side (eg, <$500) that were a bit poor in terms of soundstage. I can say with some experience that it may be at least partly true because when you plug in the Schiit Wyrd before the Dragonfly, the little dongle becomes a different beast altogether.
Compared to the DT880s, these are airier but meatier, if that makes any sense. The vocals were thinner on the DT880s.
Not difficult to drive at all. I drive them through an LG G3 and an iPad Air. The iPad provides a max of ~1V/channel and I keep the volume at 50% generally and VERY occasionally, I increase it to 75% if I feel crazy.
Hope this helps.
